Unfortunately no, the TDC mark will also line up on exhaust stroke as well. You'd have a 50/50, and if it were wrong you'd be 180 degrees out. It is also advisable to not get the dorman brand part. If you look around online they have a very common problem in the casting, causing them not to fit into the block. I had this happen, and got a Paypal refund. I was ale to sand the od of the casting to make it fit, but chose not to use it anyway, because the pins holding the 2 shafts together looked weak, and were barely long enough.
