- April 3, 2008
- Gloucester City, NJ
- 98 2Dr,2,000 & 04 4dr xlt
I'm gonna need different wheels and tires.
1. Need wider tires for more traction, wider wheels for wider tires.
2. I don't want center caps that I have to remove when I go racing like the factory ones I have now.
3. Don't want to go much heavier if possible.
4. Can not go much smaller in total diameter since I am going through the traps close to max rpm. I do have a little wiggle room, I can change shifts points to go a little higher and I am not exactly at my highest RPM either. Current tire diameter is supposed to be 30.1 inches. 255 70 16 Goodyear Wrangler RTS.Tire tread width is only 7.2 inches.
May be able to go with a 28 or 29 inch tire, haven't computed it yet.
All 4 tires have to have the same outside diameter because of the automatic
4wd system.
5. Wheel lug nut spacing is 5 x 114.3
I would like to go with a larger diameter wheel, maybe 17 or 18. Don't know yet. I really don't want to go with a super low profile tire because the wheel well on an explorer is quite large.
I plan to lower the vehicle a little and get rid of the step bars, if I can find the right wheel/tire combo.
I will edit this post as I come across other things.
I also don't like how the rear wheel flare sticks out so much and the wheel sits in. See yellow arrow in second picture.
4wd system.
