Troy H
- June 3, 2011
- Columbia Gorge, WA
- 1996 XLT
Hi All,
I seem to be stuck trying to get to the ball joints on my 1996 Ford Ranger 4.0 4wd. Any help with this would be appreciated.
I've spent much of this week researching my ball joint replacement project and found very little that pertained to the 1996 Dana 35 IFS (pretty sure). Most detail 1998 and later which have a different suspension. Mine looks like this:
The closest thread I've found detailing the procedure on a similar system is this thread relating to a F150. On the F150, the wheel hub is removed and the axle shaft is then pushed through the knuckle - which then allows for work on the ball joints.
This differs from my system in that my spindle is held to the knuckle with a small brace that can't be removed (located at about 3 o'clock in the photos), then the bolts were punched through from the rear of the knuckle. The axle travels through this spindle.
I tapped the bolts out pretty easily, but because of the axle, I am still unable to remove the spindle.
So, following the logic of the thread I was using, my plan was to bring the axle out through the knuckle, but because the spindle is in the way, I cannot do this. Also, the joint appears to be larger than the hole in my knuckle anyway.
So, how do I remove the axle and the spindle to continue my work? Is there a way to separate the axle shaft from the stub shaft and pull the axle inward?
Thanks in advance for your help.
