reserved50
- April 21, 2005
- 2013 Sport Exploder
Mines a 2011. What it does is extend the range or make the range of the factory keyfob more reliable, it wont extend it by much, it has to be placed at the top of the windshield or under the headliner so the wire has to be extended. You remove the back of the center console off by pulling the top part back and it pivots away from the floor, youll see the tpms module at the bottom and just plug the wire in. The real issue is the keyfob, the built in antenna just doesn't have the range.
Don't know if you have to have remote start activated for the vehicle to use an external antenna since I already had mine activated when I tested it, the range wasn't increased by much but worked slightly better through walls and when it wasn't in direct line of sight. I was only testing it so I just had it dangling off one of the seats and not in the roof area for greatest range.
Remote Start System - RFR Antenna Kit DA8Z-15603-A
