Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Sloped body lift + SOA successful
Reply
Thread Tools
Old 02-02-2005, 12:24 PM   #1
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Thumbs up Sloped body lift + SOA successful
Not sure who remembers this thread: http://www.explorerforum.com/forums/...d.php?t=105207
But I did it and have put nearly 5000 trouble free miles on it so far...
Some notes for people who might want to do this or any SOA for that matter:
• The perches I got were from M.O.R.E. offroad but the holes drilled in them are only 1/2" and the peg on the bottom of my leaf spring needed at least a 5/8" hole. So I had to drill those out.
• Also to move the axle about an inch closer and aim the pinion up slightly, I used the furthest back hole. This ending up being a key move because at first I had tons of vibes from my driveshaft slip joint almost seperating (which it did during the install when drooped) and the angle. I tried using the center hole first for a day and immediately changed it the next day. Now its smoother than it was even before the install (my stock tires which were on before were badly balanced)
• The brake lines reached perfectly fine (with a good amount of slack even) after carefully bending the bracket on the frame straight down.
• I rerouted the parking brake cables over the springs and flipped the bracket on the driverside frame. It still works perfectly and reaches fine.
• I trashed the thrid shock/dampener weight that I had and there is no noticiable difference.
• Originally I mounted the shocks on the spring plates flipped and switched sides, which would have worked except for my exhaust. I have dual exhaust pipes that go out both sides and the shocks were really rubbing and pushing on them. So instead I used the bolt and made a stud on the sway bar mount and bolted them to that. This has worked great.
The body lift part was pretty straight forward. I just jacked the truck up from the rear body and replaced each block at a time. The only thing that isn't perfect about this is now my 3in adapter for my 5spd shifter is hitting the plastic shift boot in first. Also I had to slightly modify my tcase shifter which was custom anyway.
Overall with a 2 inch TT and a 3 inch body lift up front and the 6" SOA in the rear, the truck sits fairly even with a nice little rake. Then theres an idea I had for getting another inch up front: putting 1" drop spacers in the mounts for the front axle, so I can TT another inch without stressing the CV's. Seems like it could work, but the front crossmember could be in the way of diff cover, nothing a BFH can't fix... Also, i realize the geometry would be a little off from this making the cv shaft no longer parallel ot the A arms, thats why I'm still thinking about it.
anyway now for the pics:
if your interested here is some more pics I took during the process email me for a folder of them.
Since a lot of people have private messaged me and asked me for the dimensions of the blocks and i forgot the measurements when I installed them... i redid the math to post here. First off these are measurements for a 2nd gen 4 door, if someone wants to measure a sport and let me know I'll post that here too.
Body mount #1: 3"
Body mount #2 (46" from the first mount ~28%): 2 3/16"
Body mount #3 (77" from the first mount ~47%: 1 9/16"
Body mount #4 (120" from the first mount ~78%): 3/4"
Body mount #5 (163" from the first mount): 0"
So if you are careful you can use the left over piece cut off body mount 2 for body mount 4 and it should only take 1 3" block to make the 2 sides for mount 3. So in all you should only need 5 blocks to do this. Disclaimer: These are rough measurements i did in 5 mins with a tape measure and pendulum so it wouldn't hurt to double check my math.
Nick26 is offline   Reply With Quote
Old 02-02-2005, 12:24 PM   #2
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Old 02-02-2005, 12:38 PM   #3
Con Seann3ry
Eugene, Oregon
94 XLT
Vehicle Specs
do you have a picture from the side?
__________________
http://www.cardomain.com/id/conseannery
Con Seann3ry is offline   Reply With Quote
Old 02-02-2005, 12:42 PM   #4
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Quote:
this is as close to the side as I have for now, but i can take a few more tonight...
these pics are right after I pulled out of the garage (barely fit), so the springs have settled quite a bit too since then...
Old 02-02-2005, 01:30 PM   #5
AspenX
Garland, TX Aspen,Co
AspenX's Avatar
'96 Sport 4x4
Vehicle Specs
Glad it worked for you. Looks great.
__________________
The Gene Pool needs more chlorine
96 Sport 4x4 EE swaybars Bilstein shocks class lll U-suck hitch
Specialized S-Works FSR
XTR Titanium, even the spokes and a few Carbon Fiber doodads
AspenX is offline   Reply With Quote
Old 02-02-2005, 01:44 PM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
lets see a side shot nice work
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 02-02-2005, 01:44 PM   #7
explrig91
pottsville, pa
1991 xlt
Vehicle Specs
did you keep your orginal rear and weld perches for the spring over or use a ranger rear??
explrig91 is offline   Reply With Quote
Old 02-02-2005, 01:51 PM   #8
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
I just welded new perches to my rear... and left original perches incase I ever needed to switch back
Old 02-02-2005, 01:58 PM   #9
explrig91
pottsville, pa
1991 xlt
Vehicle Specs
o just wondering, that's wat i am doin with mine tho. i got the ranger rear from a junk yard just need to install it. i figure doin a SOA and using the ranger 3inch blocks and combined with my homemade lift up front i am lookin at around 7.5 to 8inches of lift.
Old 02-02-2005, 02:01 PM   #10
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Quote:
cool, not sure about the earlier years and the rangers but starting 98 the VSS (electric) was in the rear axle, so relocating that might have been a pain if I had used a ranger axle.
Old 02-02-2005, 02:10 PM   #11
ohe_boy
Kane'ohe, Hawaii
ohe_boy's Avatar
'94 4x4 XLT
Vehicle Specs
That set up looks just like a 1st gen X. Are you planing on replacing your rear shocks and mount?
__________________
Kea Hottendorf - '94 4X4 XLT, FULL WIDTH HP Dana 44 up front with FULL WIDTH Ford 9" in the rear. 4.88 gears Lockright front and detroit back 36'' IROKs 3" BL, KKM Air Filter, Flowmaster 50 series,
My SAS Thread
ohe_boy is offline   Reply With Quote
Old 02-02-2005, 02:17 PM   #12
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'04 Jeep Grand Cherokee
Vehicle Specs
Quote:
In doing so, you will be removing another 1" of droop from your front suspension (which stinks when going down a rutted hill b/c it causes your front end to drop when the tire can't droop any more, therefore lifting the rear wheels in the air)
I wonder how hard it would be to fab new A Arms that will increase the front suspension travel
__________________
Brett
I get payed to sell and play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 02-02-2005, 02:34 PM   #13
explrig91
pottsville, pa
1991 xlt
Vehicle Specs
does neone kno wher i can just buy dropped center hinges for a 91 i have everything else for a 8inch lift just need them.
Old 02-02-2005, 03:24 PM   #14
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Quote:
not at this point, its working pretty well for me... The way they are mounted now is actually different from what you see in the pics though. They were hitting my exhaust when bolted to the flipped spring plates, so instead I used the same bolt and bolted them right to the sway bar mount bracket which has been vacant for a while. I would think someone with stock exhaust might be able to get away with bolting them to the spring plates, it's just that my duals are taking up a lot more space. I'll get another pic of that tonight too.
Old 02-02-2005, 03:33 PM   #15
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
I see what your saying but I'd have to say I don't entirely agree, cause instead of it having to droop another inch it already started out an inch lower. Its still going to still droop to the same maximum the ball joints will allow (which will be an inch less delta from before). This would really only be apparent when I only have 1 front wheel on the ground since that 1 on the ground is not going to be an inch higher. The limitation isn't really in the A-Arms, its in the ball joints, sure you could rotate the socket on the A-arms to compensate but that would just do the opposite to the up travel. I believe I read McNeil or or one of those desert racing guys had some super ball joints for this, but I'm not looking to spend much on the IFS. The only thing I'm worried about with doing the drop spacers is that it could potentionally expose the bottom of the diff if it hangs below the cross members.
Old 02-02-2005, 03:43 PM   #16
XPLORIN
OWINGS MILLS, MARYLAND
98 SPORT
Vehicle Specs
Where did you get your perches from, and did you just eye it up when you welded them in place? The only thing that sort of scares me is that this is my evryday driver and I don't want the drive shaft to fall out on me!! would you reccomend having the d/s extended??? Either than that.....you truck looks awesome!!!
XPLORIN is offline   Reply With Quote
Old 02-02-2005, 04:16 PM   #17
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
(Original Poster)
Quote:
bought them here: http://www.mountainoffroad.com/more.htm -but remember these have to be drilled, maybe they'll do that for you if you ask when you order them, I didn't know this in advance.
I definitely didn't "just eye it" I used a magnetic angle finder and made them parallel to the bottom ones, tacked them and rechecked it, then welded them on.
This is my daily driver too, infact I do 120 miles a day on this setup at 70mph+. Its tough to say if you'll need a longer driveshaft, everyone is different and I see you have a sport too. Like I said above I moved the axle forward an inch after a day of driving and that fixed all my vibration problems, so I am not planning on getting a new driveshaft.
thanks!
Old 02-02-2005, 04:42 PM   #18
XPLORIN
98 SPORT
Vehicle Specs
Cool.....thank's man.....when you say you moves the axle up an inch.......what do you mean? You moved the pin in the spring to the hole most toward the back?
Old 02-02-2005, 05:11 PM   #19
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Right on, Nick, you did it! Looks great!
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Old 02-02-2005, 05:15 PM   #20
bmxking5
Rollover Posse Member
Monroe, GA
bmxking5's Avatar
'93 Sport & '96 XLT
Vehicle Specs
Congrats Nick, nice job
__________________
Weekend Toy: '93 Explorer 2dr - Full-width D44/9" swap, disc f/r, 37" Nittos, 4.88s locked rear, hi steer
'96 Explorer 5.0 - Lifted, Magnaflow, Mac, TMH, 33s, TOTALLED!!
New DD: '01 F150 Supercrew 4x4 - Magnaflow Hi-Flow cats & Muffler, powdercoated FX4 wheels, leveling kit
bmxking5 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
