expo5.0
- October 18, 2001
- Red Wing, MN
- 1996 xlt
yep, it lasted like 6 days with the bags.
guess it didn't have a prayer of handling the angles (even though i drove with it up relatively high) and the tq of my truck
i'm not sure yet what i did damage wise though
I was accelerating away from a stop sign on campus when the front end dropped, an started shaking like the wheel was falling off. The inner cv had pulled out and blew its fluid crap all over everything. it had also punctured my air bag. the bumper was about 4 fingers off the ground so i couldn't see much. i talked my friend, tyler, into coming down and bringing a bunch of tools and we spent about 3 hours disassmbling and reassembling everything (we were tryign to pull the cv out from the wheel hub assembly, but failed) when we put it all back together we put the cv below its inner housing (we figured that would be better for crawling back home than having it in the triangular housing). that turned out to be true, and it was fairly driveable, albeit very low. we removed the inner fender and it didn't rub much so i decided to drive it home like that. there was a faint clcking all the way home presumably from the cv rotating. then about half way home a bang, and something fell off and there was no longer any noises. however when i got home there was a steady stream of tranny fluid looking fluid pooring out (i of course can't see it at all in the dark without jacking it up) and for now i don't know what it is for sure. i'm 98% certain i blew up the front differential and that is where the fluid is pouring out of. I drove a couple laps around my parking lot to make sure it wasn't hte tranny and i'm pretty darn sure it isnt.
so...
1.. what is broken. i know the extent of the damage wont' be known until i jack it up and get some more info etc., but let me know if you have any ideas etc.
2. how do i fix it- do i convert to 2wd? rebuild it as it was? is it cheaper to sort of half convert to 2wd? what do i need to do in the mean time to drive it safely, etc. etc.?
3. i bet ya'll will want pictures of the damage eh?
so...
