#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
brown wire mod
Reply
Thread Tools
Old 10-14-2005, 02:12 PM   #1
TrevorSmith
Burlington, Ontario
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
brown wire mod
I know it has been discussed numerous times and I have read all the threads on it but some things are still unclear to me. First of all where is the BEST place to hook in the switch. Underneath the seat or behind the radio? And second where do you hook up the ground wire from the switch?
TrevorSmith is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-14-2005, 03:41 PM   #2
Lee S.
Northport, NY
Lee S.'s Avatar
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
Hi and welcome... I understand the clarity issue . The BW mod has taken on a life of its own over time.
I would say anyhere from the left side of the radio (after the splice as GIJoecam mentions here:http://www.explorerforum.com/forums/...14#post1189714) to the transfer case will work since it's a straight run between these 2 points. This would include under the seat. Just don't hook it up to the right side of the radio (before gIjoe's 'splice') as many (myself included) have done in the past.
Any place you can ground the switch to the chassis will suffice.
__________________
98 XLT Sohc 4Dr 4WD Auto. Mac Intake, EE rear sway bar, external tranny filter, brown wire mod, Hidden Hitch, Monroe shocks.
Lee S. is offline   Reply With Quote
Old 10-14-2005, 05:56 PM   #3
TrevorSmith
Burlington, Ontario
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
so just cut the brown wire under the seat put in a switch and ground it to the bare floor somewhere and i dont have to worry about putting it in between all of these splices
Old 10-14-2005, 07:49 PM   #4
Lee S.
Northport, NY
Lee S.'s Avatar
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
Yep.
In this thread on page 2 there is a pic of the brown wire under the seat if that's where you decide to cut it: http://www.explorerforum.com/forums/...d.php?t=143353
Ground the switch to a bolt or screw that attaches to the chassis.
__________________
Old 10-14-2005, 08:34 PM   #5
MONMIX
I fix dents
Millersville , Maryland
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
Quoted: 70 Post(s)
I inserted my switch. Meaning, cut the brown wire, spliced in a few lengths and put the switch in my center console. and then back again.
__________________
MONMIX
ASE certified Master Collision Repair Technician
I-CAR Certified Platinum Structural Technician
Live your life for a change
My Explorer
MONMIX is offline   Reply With Quote
Old 10-15-2005, 12:48 AM   #6
TrevorSmith
Burlington, Ontario
1998 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thats a good idea, i was trying to think of a clean place to mount the switch
Old 07-14-2008, 10:47 PM   #7
4x4firefighter
Oneonta, NY
99 Eddie Limited
Vehicle Specs
Quoted: 0 Post(s)
ok so i must have missed something. if i were to do this i have to have a switch someplace that does what? one direction it can do awd and the other 2wd? again the clarity thing.....
__________________
4x4firefigher.....99 Eddie Limited.... TT/ WORRIOR shackles, BLAZER off road roof lightbar
http://www.myspace.com/axn6254_4x4firefighter
4x4firefighter is offline   Reply With Quote
Old 07-14-2008, 10:52 PM   #8
4x4firefighter
Oneonta, NY
99 Eddie Limited
Vehicle Specs
Quoted: 0 Post(s)
ummm another ?....what is the success rate of this procedure? anyone have major malfunctions or machanical problems?
__________________
Old 07-14-2008, 11:18 PM   #9
trj360
1999 XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
All the brown wire does is cuts the power to your transfer case. With the switch off, you have 2wd only. When you turn it on, you can then use your electronic switches on the dashboard to engage 4x4. The mod is mainly for people who have auto4x4 and don't want that for whatever reason. AWD is not electrical though, I believe it's mechanical. The brown wire probably isn't even present on an AWD explorer.
trj360 is offline   Reply With Quote
Old 07-14-2008, 11:39 PM   #10
4x4firefighter
Oneonta, NY
99 Eddie Limited
Vehicle Specs
Quoted: 0 Post(s)
ok so it kills that ####ing auto4wd shit..... is it save to "kill" power to transfer case? i live on a hill in a snowy area so the switch would get used couple times a day.... also would i want to turn it to auto or would i be able 2 keep it in 4hi and "kill" the case?.....
__________________
Old 07-15-2008, 01:13 AM   #11
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
The downside to this is when people use it to do too many burnouts -- the difference in the speed between the two driveshafts increases the oil's temperature and eventually kills the internals. There have been a few threads about this happening to people.
Success rate is pretty much 100% -- i mean the only way it could fail is if you cut the wrong wire . Or you cut the wrong wire, flip the switch, and out comes a banaphone from the glovebox -- actually that wouldn't be a failure, that'd be a 200% success rate, forget 2HI/4HI, i'd rather have a banaphone .
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 07-15-2008, 06:43 AM   #12
XLT Lou
Imperial,Mo.
1998 XLT
Vehicle Specs
Quoted: 0 Post(s)
I did the BW Mod this past weekend while I had the dash open to replace some dash bulbs, Works great, No more annoying studder.
__________________
1998 Explorer XLT 4.0 OHV auto 4wd
XLT Lou is offline   Reply With Quote
Old 07-15-2008, 09:26 PM   #13
MONMIX
I fix dents
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
Quoted: 70 Post(s)
just to reinerate
BWM ONLY if you have auto 4WD.
If you have 2wd then the BWM is pretty much useless. ( and rather silly)
If you have AWD then you cant do it.
__________________
MONMIX
My Explorer
Old 07-16-2008, 12:49 AM   #14
trj360
1999 XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
No. Cutting the power cuts off the power to the front drive shaft.
Quote:
When you select 4 high from the switch on the dash, the GEM sends the signal to the Transfer Case Shift Relay to engage 4 high. This sends power directly to the Transfer Case Clutch Coil, essentially a 100% duty cycle.
If you select 4 low, the transfer case remains locked, but engages a set of planetary gears to obtain the low range gear reduction. The front and rear driveshafts are still linked solely by the Transfer Case Clutch. By interrupting the power flow to the TCCC when in 4 low, the transfer case disengages the front driveshaft, even though the planetary reduction gears are engaged. This results in a true 2wd low range
http://www.explorerforum.com/forums/...brown+wire+mod
Old 05-24-2011, 07:55 AM   #15
fordguy2360
truro ns
2000 explorer
Vehicle Specs
Quoted: 0 Post(s)
worked perfect thank you very much love being able to put my 2000 explorer in 2wd
fordguy2360 is offline   Reply With Quote
Old 08-21-2011, 12:01 PM   #16
Tesserra
NOR CAL
1998 EXplorer 5.0
Vehicle Specs
Quoted: 0 Post(s)
So newbee question here.
What is the difference beteween Auto 4WD and AWD.
Is there a hi low switch for Auto 4WD?
Tesserra is offline   Reply With Quote
Old 08-21-2011, 08:08 PM   #17
albi1cnobi1
Elite Mountaineer
South Jersey
albi1cnobi1's Avatar
99 Mountaineer V6 4x4
Vehicle Specs
Quoted: 106 Post(s)
The V6 Ex's have the BW4405 t-case which has A4wd-4hi-4lo. Auto4wd is basically 2wd until the speed sensors on the transfer case sense a difference in speed between the front and rear drive shafts(such as the rear wheels starting to spin in snow etc.) then the clutch in the case engages and sends varying amounts of power to the front wheels until the speed of both shafts are the same. The V8 Ex's have the BW4404 t-case which is AWD, no ranges to switch. Power and torque to front and rear drive shafts all of the time. V6 equipped trucks have the range selector switch to the left of the radio on the radio trim, and the V8's have no switch.
__________________
Al
99 Mountaineer 4.0 SOHC. 2013 F150 SuperCrew 4x4
TT/F-150 Leaf Spring Mod, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Gibson Catback, Coilover conversion(in process), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System. EATC Mod. BW1354 swap. My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
albi1cnobi1 is offline   Reply With Quote
Old 08-22-2011, 12:26 AM   #18
Tesserra
NOR CAL
1998 EXplorer 5.0
Vehicle Specs
Quoted: 0 Post(s)
So, sounds like the V6 has a better set up for off road.
Old 08-22-2011, 12:52 AM   #19
albi1cnobi1
Elite Mountaineer
South Jersey
Vehicle Specs
Quoted: 106 Post(s)
In it's stock form, yes. A lot of people with the V8's have swapped in a 4406 t-case from the F-150's to get the same setup as the V6 Ex's. And you can tweak the V6 setup as well. Check out my swap thread in my signature.
__________________
Al
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
