| Offroad Fabrication - Bumpers, Sliders, Cages etc. For the Ford Explorer and Ranger entusiasts who like to build their own rock sliders, bumpers, rollcages etc. |
Thread Tools |
#1 |
Albuquerque, NM
1991 XLT
My rear bumper with swingout tire carrier
I made a new bumper for my Explorer and just finished it up today. It has been built in stages over the past 6 months when I had time The overall design was kept in mind so no changes had to be made along the way.
I needed a tire carrier once I got bigger tires since the new spare wouldnt fit under the chassis anymore and it was taking up too much cargo area. I also wanted a bumper to match my front bumper and to provide better off-road protection and recovery points. It also needed an integrated receiver hitch since I tow trailers on occasion. The new bumper increased my departure angle which was greatly needed. I was always hitting my rear receiver hitch on something while wheeling. Start off with the CAD design using Solidworks ![]() ![]() From there I started cutting the material. A carboard template of the frame plates was made then plasma cut out of 1/4" steel. 2 sets of holes were drilled for stock and 1" body lift height. ![]() The clevis tabs are welded to the front and back of the bumper and to the frame plates for added strength ![]() From here the bumper started taking shape. I cut a strip of 1/8" diamondplate and stitch welded it to the bumper on the underside. ![]() The bumper portion pretty much finished up ![]() The hinge is a custom design of mine. It uses a 1 1/4" socket head cap screw in double shear, a bronze bushing in thick wall DOM tube and thrust bearings. A nut was welded into the bumper before the caps were put on the sides. I use a clamp from Destaco (??) rated for over 1000lbs. The weight of the carrier when closed rests on a small Delrin pad. It also has a backstop to rest up against and protect it from swinging into the body. I drove the Explorer around and wheeled it for a few trips before starting the swing out portion. After a few months I assembled the hinge and made the base of the swing out. Then I drove around and wheeled it like that for a few more months. 1/2 way finished ![]() Then I figured I better finish it and I started to finish the swing out carrier a few days ago. Checking tire fit: ![]() Fabbing the tire hub. I found some old lugs and nuts that came off the explorer and used 3 of them. I also used some pipe to center the wheel on so when the tire is lifted up the weight can be rested on it while the holes are lined up with the lugs. It will also act as a lock for the tire. It is drilled for a padlock to fit into. The hub is on a receiver hitch that uses 2 1/2" bolts to secure it to the main carrier. This way it is adjustable for differet tires and backspacing. 1 of the 1/2" bolts will be tack welded for added theft prevention. ![]() The finished carrier/bumper ![]() ![]() And with the tire installed: ![]() ![]() The tire carrier will have modular accessories added to it later when I figure out what I want on it (hi-lift, basket, Jerry cans, etc.) They will simply bolt on to the tire carrier using u-bolts. I designed and built the carrier for a maximum size of a 37" tire which the Explorer will use at a later date. I completly forgot to add in some gussets before it was painted but will do so before a 37 is put on. It is strong enough now for the 31. Extra pictures can be seen at http://photobucket.com/albums/b141/B...Rear%20Bumper/ Last edited by Brian1; 01-05-2006 at 10:01 PM. |
#2 |
Moderator
Huntington Beach, CA
Very nicely done sir. Are you still going to make a mount for the jack like int he cad drawing?
__________________ COLIN IGNACIO FORUM RULES My 2010 Explorer - Explorer #1 (sold) - Explorer #2 (sold) - My F-150 (sold) - My Ranger (sold) - My Videos |
#3 | |
Albuquerque, NM
1991 XLT
Quote:
I also forgot to mention I picked up a new Explorer wheel for the spare from the local U-pull it for $10. It is so much lighter than the steel wheel and makes lifting it up easier, plus it matches the other 4! |
#4 | ||
Moderator
Quote:
Quote:
Again, nice work. I wish I had the tool and the space.
#5 |
Red Wing, MN
1996 xlt
very nice work and excellent welding- why did you make it THAT heavy though? or maybe it isn't as thick as it looks in the pictures.
__________________ C43 ///AMG 390/440 @ wheels + tasteful show ICE and cosmetics Explorer Roadster- 5.0, bags, all one-off body, hasn't moved in 3 years- parting out. Tahoe and G35x daily drivers- stockish Specialized S-works and p2, Giant Trance X, Marin Pine Mountain |
#6 |
Wannabe Elite Explorer
Portsmouth, OH
94 Explorer XLT 4x4
I'd guess he's over-engineering since he put a tow hitch in it. It looks good though, I like it. and when you get into the larger rectangular tubing, at least around here the thickness's are way slimmer pickins
__________________ -Ryland - Elite Explorer Registry for pics Don't be mad if I'm not around every day 1994 XLT 4x4, intake, exhaust, rear levelling shackles, 31's on Cragar Black Soft 8 Wheels, Onboard Air system Future Plans (on hold while my new job settles down) - Custom Bumpers & Tire Carrier.... Looking for the right pump to finish Onboard Air. |
#7 | |
Albuquerque, NM
1991 XLT
Its not way over engineered, it was pretty much built to industry standards from what I have seen of this type of bumper except for the hinge. A few aftermarket bumper companies have similar hinges however. The main bumper is 3/16" wall and the tire carrier frame is 1/8" wall. The diamondplate is 1/8". Only a few pieces of 1/4" were used.
Quote:
That would be cool to have on my wheels though.
#8 |
Red Wing, MN
1996 xlt
ah, i just saw what looked like 1/4- sounds about right
#9 |
Albuquerque, NM
1991 XLT
I did a little more work on it today. I bought a tire cover and made an anti-theft lock plate for the tire. The center cap still fits perfectly over the lock.
#10 |
Moderator
Huh, that's a good idea.
#11 |
Only rolled it once honey
Nitro, WV
97 4d OHV
EDIT, i just saw where you designed the hinge yourself, how is it holding up?
__________________ Josh Cassell --- WV Air Force National Guard 97 SASed explorer---RIP 06 Jeep Commander V8 2012 Chevy HD Z71 w/ 285's (company owned, I wouldn't buy it!) 2008 Yamaha Rhino-rock crawler |
#12 |
Albuquerque, NM
1991 XLT
The hinge is doing good. It is nice and smooth with the tire on there. Very little movement of the carrier when I hit the tire. I cant comment on long term because I just put the tire on today
#13 |
Nitro, WV
97 4d OHV
lol, thanks!
#14 |
Lancaster, New York
98 Sport
Nice work! When do you go into production? Can't wait to see it fully loaded (cans etc.)
#15 | |
Albuquerque, NM
1991 XLT
Quote:
#16 |
Syracuse, New York
96 XLT
nice bumper do you have to mount for the gas can and the jug done? What size tire doy ou have on it?
Edit: Just saw it is a 31 __________________ 2005 F-150 |
#17 | |
Albuquerque, NM
1991 XLT
Quote:
#18 |
Martinsburg WV
84 BII "Li'l Samson"
Looks good, I like the looks and the fact you went with 3/16 which will be more then enough. IF you get a chance I would really like to see a pic with the sun shining directly on bumper. All those shadows hide your nice work.
__________________ "2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner. "2012 &2011 All Ford Nationals" At Carlisle First place winner Bronco Trail Truck Featured in 2012 Bronco Driver Mag. Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year |
#19 |
Albuquerque, NM
1991 XLT
The best pic I have with the sun shining on it would be this one: http://photobucket.com/albums/b141/B...htirecover.jpg That was taken with the bumper pointed in the direction of the sun.
#20 | |
Martinsburg WV
| Thread Tools | |
