Explorer Express Hoodlifters!! | Ford Explorer Forums
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL '20 ST
Callsign
AB7FH
I installed a set of Explorer Express Hoodlifters tonight. They really work well.
What I like best is that they open the hood wider than the standard prop rod. This enables better access into the engine compartment. There's also no fumbling in the dark trying to find the hole for the prop rod to fit into.
Installation time was about 30 minutes. All that is required is the installation of 4 brackets and the gas cylinders. The installation manual was very easy to follow giving the exact measurements to locate the brackets. The only thing that the manual left out was a description of how to install the locking clips. After taking a good look at the ball end of the gas lifters I could see the two small holes which the locking clips had to pass through in order to secure the cylinders.
The Hoodlifters are available from Explorer Express and cost $79.95. Their part# is ISHL9194E
www.explorerexpress.com
Rick Horwitz
Editor
explorer@4x4central.com
www.4x4central.com
Here is a photo of the installed Hoodlifter. There is one on each side of the hood.
Rick Horwitz
Editor
www.4x4central.com
Ricks Explorer
