- September 1, 2002
- Lake View Terrace, CA
- '91 Navajo '99 X '19 Rngr
Well I guess I should do this thread now sense my SAS is done now. Wow never thought I'd say thouse words.
So here's how it turned out.
Here are the spec's
Front Axle
79 Bronco - Dana 44 High Pinion
Yukon 5.13 Gears
BTF 44 cover
Spicer u-joints
Warn Hubs
78 Thunderbird Calipers
Superlift FSB track bar cut down
Custom tie rod's from 1 1/4" DOM, 1/4"wall
Chevy 1 ton TRE's
7* C-wedges (need to go to 4*)
Wild Horse 5.5" Rock Crawler coils
BBCS 15" Shocks
Early Bronco Coil Buckets
Custom 48" long Radius Arms
Modifed Bronco RA mounts
Russell brake lines
First gen Explorer steering box
First gen Explorer steering shaft
Rear Axle
89 Bronco 8.8
Yukon 5.13 gears
BTF 8.8 Cover
Powertrax No-Slip locker
Currie custom disc brake rotors
Explorer disc brakes
BBCS 15" Shocks
Spring over leafs.
Extra's done during swap
Wenco custom rear shaft
Extended Explorer front shaft
1354 Manual T-case
35" Goodyear MT/R's
Bassett Black D-hole Rims
and some highlights pics.
and now she is done.
The full write up can be found here
Please feel free to ask any questions
Here are the spec's
Front Axle
Yukon 5.13 Gears
BTF 44 cover
Spicer u-joints
Warn Hubs
Chevy 1 ton TRE's
BBCS 15" Shocks
Russell brake lines
Rear Axle
89 Bronco 8.8
Yukon 5.13 gears
BTF 8.8 Cover
BBCS 15" Shocks
Spring over leafs.
1354 Manual T-case
35" Goodyear MT/R's
