wanderer351
- September 10, 2000
- Columbus,OH
EDIT for spec's
current sofar 1-11-07
exocage done by www.bbpfab.com -Pottsy is an awsome dude..and a great friend..
SAS (solid axle swap)
hd Low pinion D44 (8lug 1 ton)converted to coils and radius arms.
sterling 10.25 moved spring pearches...(prolly gonna movem outboard later)
current setup
4.0L V6-exausted..worn out..
A4LD-still surviving..dunno why..double tranny coolers help.
Stubler..5 3/4in double reduction t-case custom made by www.4-x-fab.com serial # XFAB-01
1354 stock electric shift transfer case
TTB d35 with prototyped application from www.aussielocker.com (those guys worked with me to find an off the shelf unit that would fit the ford TTB35's..currently now offered..and my install linked from their main site)
8.8 with aluminum IFS cover and whooped/worn out L/S
35x12.50x15 TSL swampers..
VIVAIR OBA compressor from Chubby at www.4wheelparts.com PARMA OHIO store.
OBA storage via scuba tank
superlift super-runner steering
rancho 5000 shocks.
6in skyjacker 2 lift. front
added leafs and 1.5in LIFT shackles from WARRIOR (also Chubby at 4wp) re-drilled to stock length..
rocklights that get busted off all the time.
interior lights for wheelin with the kid.
and my pride of the truck..
DANCIN HULA GIRL..shakin her money maker down every trail!!
hacked all the lift and axles out..
rebuilt the HD44 bearings/ball and U-joints (upgrade to spicer 760's Via Cowboy from COWBOY'S MUDRUN at Heath,OH NAPA store)
moved sterling's pearche in about 2in each side..and 3/4in thick Ubolts from S&S spring Mt.Perry,OH..(those guys are great!)
custom crossmember.
custom axlemounts
6in EB coils (softer spring for better ride/flex)
Craiger 15x7 8 on 6.5 rims to keep my 15's
custom beadlocks from www.DIY4X.com
building radius arms currently..ran out of mig wire..
older posts...will try to get most of the info transfered to here...main thread here..
http://www.offroadohio.com/forums/showthread.php?t=1110
I got a bug in my butt and decided to prep the rear axle for the explorer...(after busting the 3rd driveshaft..)
so I spent 2hrs chopin off the old shock mounts and spring perches...and rewelding the perches for the explorer spring width..now to get the porta-ban from work to start removing the extra webing from the bottom of the sterling..
busted shaft.
todays work..
I got more done today..brought the porta ban home from work and trimmed the fat off the axles...also got all the old brackets off the 44..
now its time for some BJ's (ball-joints :wiggle to ) and universal joints..then onto brackets welded on the front..then arms...
its commin...
what it looked like before..(well..actually its one of the other sterlings I have..but same thing)
after trimmin the fat..
44
before
after
WHOOT!!...Cowboy is givin me the hookup...OEM balljoints AND spicer upgrage 760 joints...AND gettin HIS price from the local spring shop for U-bolts (they want $50 at the parts stores for 4 freakin u-bolts!!)...
friday it should be ready....(well had to get the u-joints shipped in...so I'll gather it all the same day)...
time to go home and pull some axles!!!
current setup
rancho 5000 shocks.
custom crossmember.
custom axlemounts
busted shaft.
todays work..
its commin...
44
before
after
