jbhebert
- August 11, 2004
- South Deerfield, MA
- '94 XLT
Recently, I noticed belt noise coming from my '94 Explorer V6 with about 178,000 miles. Shortly thereafter, I started hearing a scarier noise - the fan contacting something as it spun. I shut the truck down and investigated and found that the tensioner arm assembly had failed at the pivot point and was backing out into the fan:
You can see the nicks on the fan blades where they made contact. You can also see how ****ed the tensioner is relative to the other accessory pulleys:
I removed the belt and the tensioner assembly litteraly fell apart. The tension of the spring against the belt that was all that was keeing it together. Here are the parts of the old assembly:
