What are the valve body torqe specs 5r55e | Ford Explorer Forums
sean99
Sunnyvale, California
01 Limited 5.0
What are the torque specs for a 5r55e 99 4x4 valve body.I need the foot pound specs for the three seperator plate bolts,the valve body bolts,rev. servo bolts and the pan bolts.Thanks
Pan bolts I usually to do 100 in. lbs. A guy in the transmission business told me that was usually a safe bet.
-Drew
3 bolts on separator plate 7Nm (62 in-lbs)
valve body bolts 8-11 Nm ,(71-97 in-lbs) reverse servo cover same..
pan bolts 13-15 Nm (115-133 in-lbs
No cheating trying to use a ft lb torque wrench, these are INCH lbs!!!
Torque
Sorry,I ment inch pounds.That was a brain fart caused by the stress of this valve body.:confused:
Ft / In / Nm pounds of torque
Is there a simple formula to convert these settings to my foot pounds torque wrench? Maybe I should just get another torque wrench, one that measures in inch pounds.
