IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
Not sure if this even deserves its own thread but I'm bored so I'm going to start this thread anyway for my Explorer's full hydro steer.
The all important hydraulic cylinder. 2" bore 8" stroke, double ended.
The CharLynn/Eaton steering valve.
Some hoses. 4,500 PSI rating, fire proof <-- ahah
I also have the "steering column" that bolts to the top of the steering valve.
I have the fittings that adapt the hoses to the steering cylinder. The other fittings needed I plan to get from the local hydraulics shop around here.
The 3/4" heims that are going to thread into the ends of the hydraulic steering are in the mail so hopefully in a few days I'll have em.
For cooling, I'm going to use what I'm already using for cooling the steering fluid -- which is a transmission cooler pulled from a 1st gen Explorer. I picked this cooler 'cauz its about half as thin as the 2nd gen Explorer's transmission cooler so it was easy to weld in front of the radiator support.
And since every project has to have a timeline, I plan to take this easy since I'm still mostly focusing on the Suzuki. So hopefully I'll have this installed and running in a month or so.
And since I'm a Senator, I know Brooklyn is going to ask where I got these parts from (read below)
