| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Alberta
2001 Explorer Sport 4X4
DIY: Replace Oil Pressure Sensor
Whenever I started my 2001 Explorer Sport the oil pressure gauge sat at zero (which is quite scary) until a few minutes later when the gauge jumps up to a normal reading.
Since there was no pinging and my Explorer hadn't exploded I decided it was probably the oil pressure sensor. Go to FORD to fix it? F-that. Fix it yourself for $15 and 20 mins of your time: ![]() Start by taking the drivers side tire off and peeling back the small upper bit of the rubber wheelwell ![]() Look in from the wheel well. This is the culprit with the single white/green wire comming out of it. Start by unplugging the connector. ![]() Unplug that sucker and unscrew it using a deep socket. ![]() Old and new. Screw it in using your hand first, then tighten with a wrench. Put everything back in reverse order (plug it back in, replace the wheel well, put on your tire, etc.) ![]() The gauge pops right up every time you start it up. Problem fixed. |
#2 |
Duluth, MN
'99 Sport
I had this same problem on my V8. The sensor is in about the same location. It was a little tight getting a socket in there, but I used a really long extension.
Great pics. __________________ '99 Explorer Sport 5.0 AWD t-case with 2wd spindles (identity crisis) '99 Explorer XLT 4.0 SOHC 4x4 for daily driver/off road use |
#3 |
Maryville,TN
'01 ST 5.0 AWD
Waited for nice weather I see.
Great write-up.
#4 |
Decatur, Illinois
00 Sport
Great write up. Now I can get mine working right.
__________________ Trail Rig - '00 Sport 4X4, Mobile 1 Full Synthetic, K&N Air Filter, Cherry Bomb, TT/shackle & 3"BL, 35x12.50/15 ProComp MT'sDaily Driver - 04 F150 - Silver, 4X4, Black 20x9 American Racing Clash rims with 275/65R20 Goodyear Wrangler AT/S, dual straight pipes, tinted windows |
#5 | |
Allendale NJ
1999 5.0 Mountaineer
Quote:
Thx Lee |
#6 |
Duluth, MN
'99 Sport
It is real hard/impossible to see unless you look through the drivers fenderwell. It is at the front of the block drivers side.
#7 | |
Allendale NJ
Quote:
Could not view the pics at work so I guessit is pretty much the same as the 4.0? I should just remove the wheel, it is in basically the same place ? Thx Lee Last edited by Yaco; 03-24-2008 at 09:43 PM. Reason: spelling |
#8 |
Thanks!
Thanks so much for the pictures of where this is and how to fix.. I have been needing to do for a while and have just put it off because I wasn't sure where the sensor was, etc.
#9 |
Allendale NJ
Hi,
Sensor was the problem.. Now to Fix the bulbs in the dash, Front Pass. side Door acctuator, Right Rear Door Window motor, and the pinging. With the pinging 99% goes away 89 Octane gas. I have not changed the plugs or wires inat least 75-80k miles. I got it used from the dealer and they said they replaced them @25k. Could this be the Pinging issue? Thx Lee Last edited by Yaco; 04-04-2008 at 10:43 AM. Reason: spelling |
#10 |
Zombie Prepper
Queens, NYC
99' XLT 5.0
i didnt know anyone would have the same problem if i went to the auto parts store what is it called , oil pressure sensor? nice write up
__________________ 99' 5.0 V8 XLT-FORD Red, Hella 500 Fogs,Pioneer AVIC D1 Navi, Sony DVD Player,TT/Shackles, AAL, Custom Rack lights, Rancho 5000's, LED Puddles, Custom Front Tow Hooks Many More Mods to Come
#11 |
Duluth, MN
'99 Sport
Yeah, I think it is officially called "oil pressure sender" but they will know what you are talking about.
#12 |
Zombie Prepper
Queens, NYC
99' XLT 5.0
Going to do it this weekend mine usually shoots back to normal when i rev the gas if not when it warms up like you said.
#13 |
Bay Area (vacaville) California
'93 Sport 4x4
Mine is normal when the engine starts, but when I hit the Gas the pressure drops to 0 pressure. Does anyone think simply changing the sensor would fix this?
#14 |
Toronto
1998
Hello maybe a dumb question but what did you use on the treads to make a seal? Just want to know so I do not use something that the oil will eat away at. Also can it be used on other areas of the vehicle. Thanks
#15 |
Alberta
#16 |
'93 Sport 4x4
I just replaced mine. The unit I bought already had the coating on the threds. It looked like teflon, it was red and seemed thicker, but i thought i read earlier in this forum that a "semi-conductive" style tape should be used.
#17 | |
Phoenix...Greatest City on Earth
1995 EB & 1999 EB 5.0
Now if Ford would have just put an actual gauge in these things I would be happy. My understanding is these "gauges" are nothing more than glorified idiot lights. On and off...that's it. It does nothing to read actual pressure. I actually had to start my new engine with a manual gauge installed so I could see what my actual pressure was.
__________________ http://banners.wunderground.com/weat...AZ/Phoenix.gif Quote:
#18 | |
Sykesville, MD
'00 XLS, '03 Sport
Quote:
__________________ 2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body My 2000 Explorer |
#19 |
Davis, CA.
'00 Limited 4x4
Excellent Post--Thanks!!
I did it...I am official do-it-yourself-er. Thanks to your posting and the excellent picks, I managed to get the job done and save myself some money. I did have some help though because I could not loosen the sensor myself. I need to work on my muscles I guess
...thanks again!!! ![]() Vera |
#20 | |
Old and in the way
Humboldt, Kansas
2000 Mounty
Quote:
| Thread Tools | |
