onthefritz
- December 26, 2007
- 2001 Ford X Sport 2WD
Ok, So Ive searched through thread after thread looking to find a similar solution or problem to my extremely annoying knocking sound that I cannot find for the life of me. Sounds like the body is coming off the frame, but hitting the frame with a solid knock. I know its on the passenger rear side. Ive ridden in the back while a friend drove over bumps in hopes to locate the problem. I put in new rear shocks knowing they were bad but again, hoping to resolve this knocking problem as well. In the process of changing the shocks, I noticed the leaf springs front attachment point to the frame had a bolt missing. What to me would make sense as to what the sound is like I added a new bolt. This did not fix the problem. I also noticed the muffler mount absorber thing, moves around a lot so we stuck a towel in between the frame and muffler hoping it might be hitting the frame. The mount doest have a crack in the rubber absorber. Anyone else have experience with locating this sound and do you have a solution for a fix? Ive checked bolts and have not had success with this. Please advise and thanks in advance for any responses. Its almost as if the body is knocking up and down on the frame. I have somewhat a similar instance in the front passenger side like the dashboard is coming off hitting down...
Fritz
Fritz
