BT93's sloped BL thread | Ford Explorer Forums
bt93
NE Arkansas
97 Eddie V8
Just order the pa-853 from summit racing via an e-bay listing. I intend to do the sloped BL with a combination of f-150 and stock ex springs plus the shackles until i can afford the Superlift springs. I'm really not interested in the SOA due to the fact I'll have no sway bars and most of the pics I see look a bit too tall in the rear. I'm really picky about my stance. Hope this works out the way I've planed. Any suggestions? This task should start in about a week or so.
I'll post a some pics of the process.
Alright, change of plans! I found a deal on e-bay for Fabtech 3.5" superflex rear lift springs for a gen 1 2wd. Will these work? Every bone in my body was telling me they will! So I bought them. Hope it all works out.
I don't see why they wouldn't, they're probably made to match the 3" lift spindles for the 2wd ex's
I'm super stoked about this whole project!
Aren't the first-gen rear axles spring-over, while the second-gen are spring-under? Doesn't that change something on the spring mounts?
No sir the 1st gens are spring under.
And 2nd gen springs can be used on 1st gens.. Our OME-36 springs were made for a 1996 and worked prefectly on our '92.
~Mark
All explorers from the factory 91-01 including sporttrac were SUA (Spring Under Axle) I think they did this to prevent axle wrap.
OK, ok, just askin'... I'm admittedly not up-to-par on my 1st-gen knowledge. I never owned one of those... Came close before the Ranger, but never found one in my price range that didn't need a new front end... Just had to ask the question, that's all.
-Joe
im assuming the V8 suspension varies from mine?
Anyone know the Block measurements for the sloped BL?
Whats a block measurement?
Ohhh measurements of the pucks.. got it.
Looky!!
