- March 4, 2007
- anaheim hills,california
- 95 ranger 4x4/ 91 X 4x4
Your Stock Auto/Manual hub info - Ranger / 91-94 X /BII
...If you own a 90-97 Ranger or a 91-94 Ford Explorer with manual hubs, this is for you..:biggthump
Manual Hubs
_________________________________________________________________________________________________
...Your stock Manual hubs are made by Warn for Ford...
Dana 35 - 27 spline
...The Replacement Part Number for your hub is = Warn P/N 29071
...The service kit for your manual hub is = Warn P/N 39128
..From the Manufacturer
For 61-70 International Harvester Scout; For 71 & Prior Jeep Cj/Universal/M38Ai/Willys; For Jeepster C101 Commando; For 73 & Prior Jeep Gladiator/Wagoneer Pickup
The WARN Premium Hub is a no-compromise hub designed for the hardcore off-roader or truck owner who will accept nothing less than the industry standard in performance.
The all metal construction and ZA Alloy dial ensure years of reliable functioning. This dial requires a full 9/10ths of a turn to ensure positive engagement of the inner drive gear to the clutch ring. To make sure they stay engaged, WARN premium hubs use a thick internal wave spring and heavy dial detents.
We know our premium hubs will be used hard, so we build them to last. We're so confident, that all WARN hubs are covered by a lifetime limited warranty.
All WARN Premium Hubs feature:
9/10 turn dial for robust engagement/disengagement
Heavy detents for positive engagement
Wave spring technology increases reliability over standard coil springs.
All metal construction
ZA Alloy dial with dual seals keep contaminants out
..Product Description..
These manual hubs are designed for OEM hub replacement. They feature a precision cast body, 4140 steel clutch ring, and inner drive gear. Installation is quick and easy and sure turn dials make for easy engagement. For use with 27 spline axles.
Compatible with the following models:
90-94 Ford Explorer;
90-97 Ford Ranger;
94-97 Mazda Pickup;
90-94 Mazda Navajo.
Standard Manual Hub Kit; Precision Cast Hub Body - Inner Drive Gear - 4140 Steel Clutch Ring -
Ideal For OEM Hub Replacement - for
FORD EXPLORER V6 4.0 245 1991-1994,
FORD RANGER L4 2.3 140 Standard Side Bed 1990-1997,
FORD RANGER V6 2.9 177 Standard Side Bed 1990-1992,
MAZDA B2300 L4 2.3 4 Wheel Drive 1995-1996,
MAZDA B3000 V6 3.0 4 Wheel Drive 1994-1996,
MAZDA B4000 V6 4.0 4 Wheel Drive 1994-1997,
MAZDA NAVAJO DX V6 4.0 4 Wheel Drive 1992-1994,
FORD RANGER V6 3.0 182 Standard Side Bed 1991-1997,
FORD RANGER V6 4.0 245 Standard Side Bed 1990-1997,
FORD RANGER SUPER L4 2.3 140 Standard Side Bed 1990-1997,
FORD RANGER SUPER V6 2.9 177 Standard Side Bed 1990-1992,
FORD RANGER SUPER V6 3.0 182 Standard Side Bed 1991-1997,
FORD RANGER SUPER V6 4.0 245 Standard Side Bed 1990-1997,
MAZDA NAVAJO LX V6 4.0 4 Wheel Drive 1991-1994
__________________________________________________________________________________________________
...For earlier Rangers and Bronco II's (83-89) = Dana 28 - 23 spline
Early Models With 23 Tooth Axle Spline Requires 1989 Hubs - warn P/N 29070
Auto Hubs To Man. Hubs Use Spindle Nut Kit (1983-1989) Vehicles. Spindle Nut conversion Kit -Warn P/N 27988
......The service kit for the Dana 28 hub is the same as the kit for the Dana 35 hub = Warn P/N 39128
Dana 35 = Ranger 93-97 -Explorer 91-94 = 27 spline
Automatic Hubs To Manual Hubs Use Spindle Nut Kit- Warn PN[32720]
...Note:
..For a replacement part for the Warn Brand Conversion Kit($87), you may purchase the Spicer kit pn# 28068X in stock, ($10 per side) from 4wheelparts.com...They have to look it up but they have them...
http://www.explorerforum.com/forums/showpost.php?p=1867081&postcount=457
...For some other useful schematics, try these...
...For the Ranger...
Dead Link Removed
...For the 91-94 Explorer...
http://www.explorerforum.com/forums/showthread.php?t=232576
The stock Auto Hub info..
Fits Rangers 91-97 and Explorers 91-94
A place to order new Auto Hubs - http://www.1aauto.com/1A/4WDrive/Ford/Explorer/1AFWH00001/
...For a direct replacement, stronger and heavier built hub, try the Warn P/N 37780 made for J**P
These have been recently discontinued so if you can find them, get em now...
Need to find a new Splined washer???..
...The splined washer is a "variable part" but can be found in this kit at the Ford Dealer - P/N F57Z-3B458-A is the part number, it's 3 washers. Plain steel, plastic, and the splined steel washer ...
...This 3 pc. package can be seen is this pic...
...Some other very useful Hub related links...:biggthump
...Auto hub Testing...
http://www.explorerforum.com/forums/showthread.php?t=206722
..Auto Hub and Manual Hub Socket Info..
http://www.explorerforum.com/forums/showpost.php?p=1957153&postcount=2
...Auto hub to Manual hub Conversion
http://www.explorerforum.com/forums/showthread.php?p=1809056#post1809056
..Auto Hub Problems/Repair
http://www.explorerforum.com/forums/showthread.php?t=201782
...Auto Hub/First Gen Brake Diary..
http://www.explorerforum.com/forums/showthread.php?t=122696
..How to engage 4x4..
http://www.explorerforum.com/forums/showpost.php?p=1951758&postcount=2
..How to Troubleshoot 4x4 problems...
http://www.explorerforum.com/forums/showthread.php?t=202166
..I was having a problem snapping outer spindle nuts...
http://www.explorerforum.com/forums/showthread.php?t=199915&highlight=wheel&page=6
...I figured out that I was snapping stock Dana 35 outer nuts...They are thinner than the replacement part Spicer kit pn# 28068X which in fact come back to a Dana 44 replacement part...
..Spicer part on the left and stock Dana 35 on the right...
...Per wiki...
http://en.wikipedia.org/wiki/Hubs
...From Warn Ind....
http://www.warn.com/powertrain/company_milestones.shtml
Manual Hubs
Dana 35 - 27 spline
90-97 Ford Ranger;
94-97 Mazda Pickup;
90-94 Mazda Navajo.
...Note:
Dead Link Removed
...Per wiki...
Hub means the centre of a wheel. By analogy, it generally means 'center' or 'important place', and may refer to:
# Locking hubs, accessory on four-wheel drive vehicles
1948 Arthur Warn invents the Locking Hub in Seattle, Washington
1954 WARN locking hubs are offered as optional factory equipment by major domestic automotive manufacturers
