jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
****EDIT***
this fan does not keep up for me and is getting removed
so after going through 2 fans and not wanting to pay $300 for a fan,i started looking at the Taurus fan and mk8 fans but didn't really like that it had to be trimmed and cut to fit.so with the suggestion from Mark i started looking at the Chevy HHR fan.its rumored to pull somewhere between the 2 other fans.i got it today and in 15min the thing was installed,it fit perfect!!all you need to cut is the 4 tabs on it and there is a little over hang on the bottom but it not that much and doesn't hit anything so why mess with it.i took and drill two holes on the top and two on the bottom and put bolts through it into the top and bottom lip that on the radiator.i installed this on an all alum manual radiator but it also fit on my automatic rad..o and the cost was $58 to my door from Rockauto(with our discount code also)!!!! EDIT............. will not fit on a auto radiator without trimming or something!
cut these four tabs off
and drill four holes where they line up with the lip on top and bottom of the radiator,with the fan flush with the top of the radiator and your done
just a little overhang but doesn't hit anything so i just left it alone
funny pic but there's plenty of room!!
