#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Help with engine cutting out while driving
Reply
Thread Tools
Old 01-04-2010, 02:07 AM   #1
WillyKonick
George, Western Cape
1998XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi all- this is the closest place I can find to seek advice for a problem. Please let me know if there is a better place to post - thanks. I have a 1998 XLT which has the following problem: while driving, the engine light starts flickering on, then the engine starts losing power until it cuts out all together. This is obviously very dangerous as you lose power steering! It seems to get worse when the weather gets hotter and also happens more often when turning left! (Right-hand drive vehicle here in South Africa). I found an owner of a similar model here locally who also had a similar problem and he advised us to clean the crank angle sensor which we did. It got the vehicle starting again, but after a couple of days the problem returned. If you let the vehicle stand for a couple of minutes, it starts up again, goes for a few kms and then repeats the process. The local dealer is not really interested in helping me as the "vehicle is too old!" and we would need to carry the diagnostics computer around with us in the car to wait for when the problem might occur again. Please if someone could help to diagnose the problem I would much appreciate it. Thanks!
WillyKonick is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-04-2010, 02:32 AM   #2
jb84
Cullman Alabama
93 Eddie B.
Vehicle Specs
Quoted: 0 Post(s)
My car is doing the exact same thing execpt it wont crank at all now plz plz plz someone help him. and me of coarse
jb84 is offline   Reply With Quote
Old 01-04-2010, 06:43 PM   #3
jb84
Cullman Alabama
93 Eddie B.
Vehicle Specs
Quoted: 0 Post(s)
bumpo for this man
Old 01-04-2010, 09:22 PM   #4
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 77 Post(s)
Get the codes read, and report back
__________________
2000 Ford Explorer SOHC 4X4 310,000KM
2000 VW Beetle 1.8
1991 BMW 735iL
bluestream1 is offline   Reply With Quote
Old 01-06-2010, 01:55 AM   #5
WillyKonick
1998XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks - we'll do so and report back
Old 01-06-2010, 07:22 AM   #6
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
DTCs?
Quote:
Originally Posted by WillyKonick View Post
. . . while driving, the engine light starts flickering on, then the engine starts losing power until it cuts out all together. . .
If you let the vehicle stand for a couple of minutes, it starts up again, goes for a few kms and then repeats the process. . .
If the CEL illuminated you should have diagnostic trouble codes set. Do you know what they are?
It could be a crankshaft position (CKP) sensor since the CEL illuminates. It could also be a fuel pressure problem. If its been more than 30,000 miles since you changed your fuel filter I suggest that you replace it. Why change fuel filter?
Then I suggest that you perform the Fuel pressure test procedure
2000StreetRod is offline   Reply With Quote
Old 01-06-2010, 10:11 AM   #7
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
as suggested, try changing the fuel filter. Odds are the "check engine" light coming on is more of a sign that the engine died than a failure (just like turning your key to "on" and leaving it there).
budwich is offline   Reply With Quote
Old 01-07-2010, 02:33 AM   #8
WillyKonick
1998XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks
Thank-you all for your advice. We will try these procedures and report back on outcome. Kind regards!
Old 10-07-2011, 10:52 PM   #9
kschlege
'02
Vehicle Specs
Quoted: 0 Post(s)
my 2002 4.0 stalls while driving. were you able to fix your stalling problem?
kschlege is offline   Reply With Quote
Old 10-20-2011, 10:46 AM   #10
kschlege
'02
Vehicle Specs
Quoted: 0 Post(s)
I think I found my issue. The connector to my inertia switch is melted. I checked it before, but never pulled out the connector. No idea why it would have melted.
So until I get a new plug and inertia switch, I just shorted the connection with a wire. Hopefully I won't roll it over or get into an accident in the meantime.
So a 50cent part has cost about $700. I've taken it to ford dealer twice, midas once, replaced the fuel pump and a ton of sensors, etc... Some stuff needed to be replaced anyways, but I spent about $300 at ford and midas having them trying to diagnose the problem.
Before I had just pulled the cover off and checked the connection, but never removed it ... stupid me ...
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
