Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Raybestos or Moog Ball Joints?
Reply
Thread Tools
Old 01-30-2010, 12:16 PM   #1
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I've got to get around to doing my front ball joints, radius arm bushings, and sway bar bushings before this spring.
Local auto parts store wants about $30 each for lower grade ball joints, and about $60 each for the professional grade MOOG ones.
I've used MOOG in my Dodge Stratus for Tie Rod Ends before, and they were a perfect fit, high quality. I've also heard that Ford started using MOOG ball joints in the 3rd generation explorers.
I'm planning to get all my bushings / ball joints through RockAuto. I know Raybestos has good brakes, but I haven't tried any of their other products.
They have the lower grade ball joints for about $8 each, and the Raybestos Professional Grade ones for about $26. The moog ones start at $38 each.
I'm not planning to buy any cheap crap, like those "Auto Extra" or "Coni-Seal" ones. Has anyone used the Pro Grade Raybestos with good results?
I've also noticed they carry the factory Motorcraft ones a little cheaper then the MOOG. and both the Raybesto's ones and Moog are greasable. My Factory ones are not. Thats why they're gone.
__________________
-1994 Explorer XLT Green, 208,000km, 5.5" duff lift, 35" BFG All Terrains, 4.0L 5 speed, manual shift T Case, KKM Air Intake
-1994 Explorer XLT Black.[298,100km]
Retired
mechjames is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-30-2010, 01:00 PM   #2
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
MOOG!!!
I went with the cheaper brand and they broke within 3 months... when I got the MOOG stuff I was impressed just by the quality of them BEFORE they went into the vehicle.
Suspension and Brakes are the two places I never skimp on money. But as far as balljoints, and someone that's used them, MOOG definitely stand up to everything you can throw at them.
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 01-30-2010, 01:06 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
I used to run Moog ball joints, but I didn't have good luck on the last set, and I read about others having some issues.
I then swtiched to McQuay Norris Extreme duty or Spicer ball joints. The Spicer ones are sold by Napa. Napa carries 2 types.. cheap and good.. The good ones were the spicers.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 01-30-2010, 01:08 PM   #4
TooManyTrucks
Michigan
95 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Just fyi...Raybestos is the new marketing name for Spicer front end parts...Good chassis is good..cheap chassis is..well cheap. In Auto Parts you get what you pay for...both moog and Raybestos market a 2nd line of chassis that is of lesser quality...
__________________
2002 Explorer 4.6 V8 / '95 Explorer Eddie Bauer 4.0
'99,'00,'01 4x4 Rangers
'86 Full size Bronco 351 SVO / '70 Baja Bug
'85 C10 Chevy
'85 RX7 w/ 5.0 HO Ford and a 1970 Mustang 5.0 HO...
TooManyTrucks is offline   Reply With Quote
Old 01-30-2010, 04:32 PM   #5
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
~Mark
We both have a first generation Explorer. What kind of problems did you have with the Moog ones?
Quote:
So the higher end Raybestos is the High end Napa Spicer Ball Joints?
__________________
Retired
Old 01-30-2010, 07:26 PM   #6
TooManyTrucks
Michigan
95 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Both NAPA and Raybestos use Affinia Group products... which boxes for Napa. Affinia owns brands like Wix Filters, Raybestos, Spicer, and many more...Federal Mogul owns Moog, Wagner, Precision, Carter...NAPA doesn't make products..they buy and put in their box...Most quality auto parts stores..not big box retailers which try to be the low cost providers..have an economy line as well as the premium line...
Trust me I have been in the aftermarket for 25+ years..."you get what you pay for" If it is cheap..it has less material, is lower quality and "may" not perform as you would like...there are always better prices, but a $12 ball joint is not the same as a $22 piece...
__________________
'85 C10 Chevy
Old 01-30-2010, 07:38 PM   #7
Elessar65
Wichita, Ks
98 Sport, 95 Ranger SAS
Vehicle Specs
Quoted: 0 Post(s)
I have the Spicer Pro grade upper and lower ball joints in my 2nd gen. I have been very satisfied with them. That being said though, I don't see there being much of a difference between the Moog high quality units and the Spicer ones. As someone else mentioned, you get what you pay for. I have also heard the McQuay Norris Extreme joints are a good product as well.
__________________
Wheel it, Break it, Fix it, Repeat...
Elessar65 is offline   Reply With Quote
Old 01-31-2010, 06:30 PM   #8
F150hybred
Arborg, Manitoba, Canada
1994 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Another vote for MOOG here. Only thing is, I wold go with the "problem solver" line of MOOG.
F150hybred is offline   Reply With Quote
Old 02-04-2010, 11:26 PM   #9
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 181 Post(s)
I haven't found the Raybestos joints anywhere to compare them, but the NAPA top-of-the-line joints are pretty good stuff. You can tell everything from the machined metal housing to the seals are better quality over standard joints.
Something else to consider is the NAPAs have a lifetime warranty on them. This might be the same for the Raybestos. Even at ~$40-60 each, (which isn't much more than that auto parts store is trying to sell you MOOG joints for) they're worth it. They're going to be even more worth it if you keep your Explorer and wear the joints out again and have to replace them, this time for FREE.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 02-05-2010, 01:30 AM   #10
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
MOOG has a lifetime warranty too.
__________________
Retired
Old 02-05-2010, 03:31 AM   #11
rookieshooter
Moderator Emeritus
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
Quoted: 2 Post(s)
No one has mentioned Why one is better? And the reason is, Cold forging vs. Hot forging is the answer.
Molecular structure is the key. All cheap ones are Hot forged which is a cheaper way to produce a joint over Cold Forged.
But, Hot forging rearranges the molecules in an arrangement that has less (thinking of the scientific name so I sound cool, but can't come up with one, might have to do with Mayonnase, I dunno.) strength then Cold forged.
One has to look no further then NASCAR and other major racing associations to see if they run Cold or Hot forged ball joints.
It's like a high power pistol frame, they use a 50 ton forging tool instead of casting the frame.
Now last time I heard, Moog still Cold forges.
And you can best be assured, that if it came from China, it was Hot forged. I don't care what warranty it has.
When it comes to Ball joints, like the proverbial saying, You get what you pay for.
See if the word Hot Forged is used like in Moogs link below in making a companies Ball Joints or maybe some other top quality joint producers. Basically Cold forging is stronger then Hot forging when it comes to strength no matter what your making, including just bending a piece of metal.
http://www.fpdiesel.com/en/Aftermark...ts/BallJoints/
Now check out the company TooManyTrucks mentioned, also Cold forged.
http://www.affiniagroup.com/wps/port...ringSuspension
__________________
"2013,2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
2013,2012,2011 All Ford Nationals winner. 2X first 1X second
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 02-05-2010, 09:56 AM   #12
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
I helped someone change the ball joints on an f-150 (dana 44). He put in Moog Problem solver joints. They look so much better than the regular Moog ones he had years ago. The castle nut is much bigger and the joint looks much stronger (I'm not sure how to describe it)..
That is just from looks.. I can't see how strong it really is, but I can say problem solver version "looks" much stronger..
~Mark
__________________
Old 02-05-2010, 10:35 AM   #13
kert0307
Pella, Iowa
'00 Sport and '89 B2
Vehicle Specs
Quoted: 0 Post(s)
I've got the higher end Spicers in my 2nd gen ex and they are holding up well.
__________________
____________________
89' B2 -Sold
00' Explorer Sport - Sold
05' F250 Crew Cab 4x4 Diesel Clicky tow rig/DD
2011 Ford Edge - Wife's DD
1978 Glastron CVX16 Project Boat
kert0307 is offline   Reply With Quote
Old 02-05-2010, 12:46 PM   #14
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
MOOG no friggin way never again
they used to be great, now they fail quickly on my vehicles, big tires and wheeling = they loosen up
I switched
McQuay Norris Extreme Duty ball joints
These suckers are heavy duty for a stock replacement and the price is competative
just my 02, I asked Camburg what they use on their TTB long travel trucks....this was the answer I was looking for
Napa had them for me next day
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 02-05-2010, 12:56 PM   #15
rookieshooter
Moderator Emeritus
Martinsburg WV
Vehicle Specs
Quoted: 2 Post(s)
I switched
As expected they're Cold Forged also like the link below states. Might think along these lines for my Dana 44 build. I'll find out if I can get them local, if not I'll order some.
Just seen that you said NAPA, that's good, I have one a few miles from me.
Don't understand about Moog though failing like that. Might have to research this.
http://www.amazon.com/McQuay-Norris-.../dp/B000EIXCYY
__________________
Old 02-05-2010, 01:20 PM   #16
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
Moog no longer made in USA thats why, or at least what I heard
I used to swear by them along with everyone else... but they are lucky to last two seasons on my BII anymore and I havent even gotten to wheel that sucker hard in years LOL
__________________
Old 02-05-2010, 01:21 PM   #17
Verno
Waynesboro, TN
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Go with the Spicer joints. MOOG used to be top of the line but I've never had a NAPA part fail.
Verno is offline   Reply With Quote
Old 02-05-2010, 01:51 PM   #18
mechjames
Richmond, BC
mechjames's Avatar
1994 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Alright, the concensus is that I'll be using the Spicer/Raybestos/NAPA ball joints, since they are still made in the USA, and cold forged, with a better boot.
Looking at other forums around the net, Spicer was the way to go. Hopefully under the Raybestos brand, they're just as good. Looks like now we all pay for the MOOGS are the Nascar Sponsorship.
I used the MOOG problem solver on my 1995 Stratus for Tie Rod Ends, but the auto store had them sitting around for a while, still made in the USA, and looked better then stock.
I'll try Spicer/Raybestos/NAPA brand for all my bushings now. They're greasable. A big plus from the stock ones.
__________________
Retired
Old 02-05-2010, 01:52 PM   #19
rookieshooter
Moderator Emeritus
Martinsburg WV
Vehicle Specs
Quoted: 2 Post(s)
Glad Mechjames got this thread going. Was going to order Moog next week, but I'm going to NAPA for some of those Spicer or MN extremes. Leaning towards McQuay Norris ones. Never ran those.
__________________
Old 02-05-2010, 01:55 PM   #20
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
hold them in your hand next to the moog and see which one you go home with big difference
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
