Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1996 Ignition Lock Cylinder replace
Reply
Thread Tools
Old 06-22-2010, 09:28 PM   #1
surfcjw
Jacksonville, FL
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
1996 Ignition Key Lock Cylinder: remove, replace
Well, here is my first thread/post ...
In the AM, the ignition was fine. Then I had an appointment in the afternoon, but when i got in the car and turned the key it wouldn't start. All the electrical came on, but it wouldn't start. So, i left the key in the RUN position, and jumped the starter relay to get to my appointment.
When i got to my destination, i turned the key to OFF. I had a few minutes to spare, so I tried to start it once more. Again, it wouldn't start, but all electrical came on, the fuel pump primed, the radio came one, etc. I turned to key to OFF again, but when i did nothing turned off, and the key wasnt working at all now. It would just spin inside the lock cylinder. i had to disconnect the battery to turn the electrical off, so I could go to my appointment.
To leave for home, I have to reconnect the battery and jump short the relay again. When i got home, since the key wasn't working anything, i tried to kill the engine by disconnecting th eNEG battery cable.. nothing. I tried also disconnecting the POS battery cable...nothing. I thought the battery had to be in the circuit to get spark; I guess not. I was finally able to kill the engine by disconnecting the 6-amp ignition fuse.
After reading my Haynes Guide, I ruled out the "Ignition Switch" which is located on the steering column. I decided the problem was probably just with the key lock cylinder. After taking the old one out, I saw where it was broken. I got the part for $15.99 from Advance auto: Part No. LC14390, made by LockSmart. http://shop.advanceautoparts.com/web...S_562923144___
Below is how I replaced it:
1. Per the Haynes Guide, I disconnected the NEG and POS battery cable, and waited two minutes.
2. I inserted my key into the lock, and rotated it to the RUN position. This was a little tricky since the key was spinning freely, I could no longer feel clicks between each position. The correct position has the top of the key pointing towards the shift lever shown here:
3. To pull out the old cylinder, you have to depress the pin on the bottom of the tumbler. There is a hole on the underside of the black plastic cowl where you can see the pin, and insert a punch or awl. (The pic is looking up from under the steering column)
4. So, now the key is in the RUN position, you pressed in the pin, now you pull on the key and tumbler, and it should come out. You may have to rotate the key and tumbler back and forth a little bit to wiggle it out. Now it looks like this (you can see the broken "spade" still in the lock cylinder. Sorry its a bit out of focus.
Broken piece still in there.
Broken piece removed.
Shot of tumbler and broken spade.
New lock compared to old.
5. To insert the new lock, hold the tumbler in one hand, and push on the pin with your thumb. As you do this, rotate the key a little less than an quarter-turn, and the pin should push in. Now line it up with the cylinder, and insert. Finally, rotate the key and tumbler counter-clockwise (top towards you) and the pin will lock into place.
6. Reconnect the battery, test start, reset your radio, and go have fun.
-Chet
surfcjw is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-22-2014, 07:42 AM   #2
coolshayne
shelby,nc
1996 ford explorer
Vehicle Specs
Quoted: 1 Post(s)
how do I remove the ignition switch without a key on a 1996 ford explorer
coolshayne is offline   Reply With Quote
Old 04-14-2014, 03:11 PM   #3
allend15
Dittmer, MO
1998 Ford Exp XLT 4.0 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
I have the same question for a 1998. I hope someone has an answer.
allend15 is offline   Reply With Quote
Old 04-14-2014, 07:43 PM   #4
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
vroomzoomboom's Avatar
98 supercharged 347 sport
Vehicle Specs
Quoted: 366 Post(s)
drill, and a parer
__________________
Stroke Me, Blow Me. 347 Stroker + M112 Eaton Supercharger = Evil
roll pan build for 1st and 2nd gen explorers
door switch LED convention
vroomzoomboom is offline   Reply With Quote
Old 10-01-2014, 09:00 PM   #5
Sidrycker
2000 Ford Explorer XLT
Vehicle Specs
Quoted: 2 Post(s)
If I originally have a transponder key can I replace the ignition switch with a non transponder and just lose my anti theft stuff or do I really have to buy the expensive one and figure out how to get it programmed? 2000 Ford Explorer XLT 4.0 SOHC
Sidrycker is offline   Reply With Quote
Old 10-01-2014, 09:18 PM   #6
vroomzoomboom
selkirk, manitoba
Vehicle Specs
Quoted: 366 Post(s)
Quote:
sorry, you will have to get it reprogrammed.
__________________
Old 01-27-2016, 02:56 PM   #7
king427
99 lincoln
Vehicle Specs
Quoted: 1 Post(s)
how did you get the broken piece out? i cant get to it
king427 is offline   Reply With Quote
Old 01-27-2016, 04:50 PM   #8
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
Quote:
You can Install tumblers in the new lock to your key.
http://www.explorerforum.com/forums/...=ignition+lock
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 01-27-2016, 05:04 PM   #9
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 685 Post(s)
Quote:
Will a magnet work?
__________________
Jon
2000 Mountaineer
Old 01-31-2016, 06:34 PM   #10
wejons9999
South Carolina
1996 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
1996 Explorer XLT
My 1996 explorer has the security system key. Can mine just be rebuilt with the cheap key set or do I have to replace and have the key's recoded by ford or a locksmith?
Thanks for any help
William
wejons9999 is offline   Reply With Quote
Old 01-31-2016, 07:15 PM   #11
vroomzoomboom
selkirk, manitoba
Vehicle Specs
Quoted: 366 Post(s)
Quote:
Thanks for any help
William
your 96 does not have P.A.T.S. in it, so you can just get a a key cut
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
