Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
The horn doesn't work on my 2002 Explorer.
Reply
Thread Tools
Old 10-25-2010, 01:10 PM   #1
ncsu1977
Winston-Salem, NC
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My 2002 Explorer's horn quit working - I have checked the fuses in the passenger fuse panel and they are OK- where is the horn relay located? Are there fuses for the horn relay in the power distribution box under the hood? If all the fuses and relays are good, what is the next step?
ncsu1977 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-25-2010, 06:34 PM   #2
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Here is the info from my owner's manual. If you don't have an owner's manual, it can be downloaded here.
The passenger compartment fuse panel contains 2 fuses related to the horns. #6 is a 10A Mini Fuse labled "Right Horn". #18 is a 10A Mini Fuse labled "Left Horn".
It looks like the power distribution box under the hood contains a fuse related to the horns. #25 is a 20A Mini Fuse Labeled "Security Module (horns)".
If all the fuses are good then maybe the connections at the horns are bad or the horns themselves are bad.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 10-26-2010, 02:38 AM   #3
truckboattruck
Vacaville, CA
02 XLS
Vehicle Specs
Quoted: 0 Post(s)
The horns are probably bad
I bought my 02 explorer about a month ago and didn't check the horns. They were bad. You can access them by removing the inner fenders. I replaced my horns with those from an 01 Taurus, and just mounted them on one side.
truckboattruck is offline   Reply With Quote
Old 10-26-2010, 10:36 AM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section. Does your cruise control work? Do you have a flashing air bag light? If so, then you might have a bad clockspring in the steering column.
BrooklynBay is online now   Reply With Quote
Old 12-16-2010, 06:40 PM   #5
Ratedr
Lasa Vegas, NV
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Where is the Clockspring located? and how do you replace it?
Ratedr is offline   Reply With Quote
Old 12-16-2010, 09:03 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
It's in the steering column. You have to disconnect the battery, wait a minimum of 10 minutes, then remove the steering wheel to get to it.
Old 12-16-2010, 09:45 PM   #7
Ratedr
Lasa Vegas, NV
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks!
Old 12-23-2010, 05:39 PM   #8
rollinstone
1997 Ford Explorer XLT
Vehicle Specs
Quoted: 8 Post(s)
Yep, just discovered my horn won't toot. Appears most North Americans are pretty quiet drivers, or else these things would show up sooner.
The 20 amp fuse in the under-hood box is OK (I switched 20 amp fuses). No way to tell if the horn relay is bad.
Other than those two items, what else could be bad?
__________________
Gary S. 97 XLT AWD 5.0L
rollinstone is offline   Reply With Quote
Old 12-23-2010, 06:22 PM   #9
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Could be the horns themselves, or the clockspring. Thoroughly read this thread for more info.
__________________
Old 07-21-2013, 08:32 AM   #10
panetta6pack
Queens, NY
2002 Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
ok I replaced my horns and they were working untill they all of a sudden started just going off, I pulled the #25 fuse under the hood and they stopped working when I replaced the fuse they worked fine again then like 4 hours later my horn just started going off again, so i pulled the fuse again, any help here ? could it be the security module, is there a way to bypass it or replace it?
panetta6pack is offline   Reply With Quote
Old 07-21-2013, 08:52 AM   #11
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Maybe it has a bad horn relay?
Old 07-21-2013, 08:54 AM   #12
panetta6pack
Queens, NY
2002 Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
where is it located ? I checked under the hood and didnt see any? and dose the relay work on that #25 circuit under the hood ?
Old 07-21-2013, 08:55 AM   #13
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Do you have a schematic diagram? Some vehicles have a relay but not all of them. Check # 6 & # 18.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
