ABS problems - which wheel?
How can you tell which wheel is causing the anti-lock brake system to act up (acts like a wheel is locking up).
I think that from inside the car I hear the noise coming from the front left, but that might just be because the break pedal and ABS master cylinder is on that side.
I went ahead and did a front brake job replace the rotors and calipers were fine, but I still have the issue.
Is there anyway to tell which brake the system thinks is locking up?
Thanks
Steve
Edit:
Please keep a question limited to one thread. From your other thread.
Steve, what model, and is the truck 2WD or not? 95-01 2WD trucks should have clean ABS sensors and no grease on them.
The AWD/4WD are sealed hubs with grease and the sensor goes into it. Those should be full of grease always with no air, and sealed always. Those sensors basically never fail unless damaged. Regards,
I'm having some front end issues that I'm not sure are related. ABS and 4WD issues
sehaare said:the ABS started acting up like a wheel was locking up
The ABS started kicking in when I braked hard or when braking while going down hill.
is the ABS light in the dash on constantly?
onelever... I don't believe the abs slight should come on ever during "normal" operation
I guess the question is what do you mean by "when I get this issue"? are you referring to pulling to one side during breaking?, noise coming from the front, pulling going down the highway? Basically, all / some of those could be cause by a bad caliper. When you did your front end work, and removing the calipers, did the pistons go back in "easily" or did it take lots of force to get them to "release". My guess is that you have a "seizing" caliper and its on the side opposite the pull IF the pulling occurs during braking. IF the pulling is during driving, then its likely the side that is pulling.
