BrettW
- January 7, 2011
- Chicago, IL
- 2000 Mountaineer 5.0
Howdy All!
I have the dreaded Gangster Lean on my 2000 AWD Mountaineer (125k miles). It's leaning 7/8" lower on the drivers side front, an:usd 3/4" lower on the drivers side rear. The tires were toast and it was pulling to the right, so I replaced all four tires and it drives more or less perfectly straight now. The front sway bar end-links are broken on both sides, and I bought the good blue poly end-link kit from Napa #265-1312 ($31.99), and new 34mm blue poly bushings #265-2542 ($16.99). The rear leaf springs don't look broken at all, and the truck leans just as bad with the gas tank empty or full.
My first question is, should I even bother hooking the sway bar back up before I correct the lean? I would guess the bushings will premeturely wear out if I do that, and make fixing the lean that much more difficult to fine tune.
Second question is has anyone come up with a way to determine if the cause of the lean is the leaf springs primarily verses the torsion rods? I was thinking if I put the front up on jack stands the back sag should still be noticeable if it's the leaf springs, and vice versa if I jack-stand the back the front could still do whatever it wants to do naturally. Then I could get a feeling for how much each set of components is contributing to the overall lean.
The reason I would go this far with it, is because if it's the leaf springs sagging I'll just put new ones on, but if it's not I could just adjust the torsion rods and save some money and time. However, if it is the leaf springs I don't want to overcompensate for the lean by cranking the torsion rods to their limits and wind up with a stiff front end.
FWIW, I've already been pre-soaking the adjustment bolts for the torsion rods.
Advice?
I have the appropriate threads favorited for easy reference later:
Sway Bar
http://www.explorerforum.com/forums/showthread.php?t=195135
Leaf Spring
http://www.explorerforum.com/forums/showthread.php?t=212985
If there are some I'm missing please let me know, thanks!
PICTURES!
Advice?
Sway Bar
Leaf Spring
PICTURES!
