#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
For the love of GOD, how do you disable the seat belt chime?
Reply
Thread Tools
Old 02-17-2011, 10:43 AM   #1
kdoggy
Grand Rapids, MI
2002 Explorer XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It just won't STOP!!!
Hehe, anyway I admit I don't always wear my seat belt but that damn chime is making me want to! I'm sure that is it's purpose but hey!
If I'm must here in town (25 zone) doing something quick, I don't always want to throw it on.
How can I disable the chime? I know on my Mitsubishi Eclipse it was a simple matter of unplugging something but I would still like the other warning chimes to work.
Is there a harness to the seat buckle itself?
kdoggy is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-17-2011, 10:57 AM   #2
Doomstang
St. Louis, MO
02 XLT and '91 XLT
Vehicle Specs
Quoted: 0 Post(s)
From my manual:
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
  • the parking brake is set
  • the gearshift is in P (Park) (automatic transmission) or the neutral position (manual transmission).
  • the ignition switch is in the OFF position
  • all vehicle doors are closed
  • the driver’s safety belt is unbuckled
  • the parklamps/headlamps are in OFF position (If vehicle is equipped with Autolamps, the Autolamps feature MUST be turned off.)
To reduce the risk of injury, do not deactivate/activate the Belt Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes)
  • Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled.
  • After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
Seating and safety restraints
  • This will disable BeltMinder if it is currently enabled, or enable BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by flashing the safety belt warning light four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by flashing the safety belt warning light four times per second for three seconds, followed by three seconds with the safety belt warning light off, then followed by flashing the safety belt warning light four times per second for three seconds again.
9. After receiving confirmation, the deactivation/activation procedure is complete
Doomstang is offline   Reply With Quote
Old 02-17-2011, 11:50 AM   #3
fedyfedz
Suffolk County, NY
2002 limited v8
Vehicle Specs
Quoted: 4 Post(s)
wow im about to do this right now. it really annoy me, especially when its cold, below 20. When its really cold the bell goes off but sounds like there is a dying bird in there and it is ear piercing. If gotten used to it casue it turns off after a while but when people get in my truck there like what the hell is that noise...
I now i should just throw the seatbelt on but it really is annoying when its 10 degrees and im wearing 6-7 layers and im making a quick drive/stop and the seat belt barely makes it over my carhart hahah
__________________
Sold 2002 explorer v8 limited
Current Ride:2001 Dakota v8
*Registry*
fedyfedz is offline   Reply With Quote
Old 02-17-2011, 12:00 PM   #4
Explorer Pete
Sacramento, Ca.
2013 Explorer Limited 4WD
Vehicle Specs
Quoted: 14 Post(s)
You would think that going through all of those steps, it would be easyier to just buckle the darn belt. You would be sending a message that you care about safty. If you were in other states that have the law, you would just bite the bullet and buckle up.
Explorer Pete is offline   Reply With Quote
Old 02-17-2011, 12:28 PM   #5
kdoggy
Grand Rapids, MI
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
We do, it's a $60.00 dollar fine if your not buckled up.
However if I drive from my house to the corner to get milk which is like 1000 yards and a 25 zone, I'm not too worried about a high speed crash. What I am worried about it how annoying that damn buzzer sounds because I about wanted to put a .45acp threw it today!
It not so much about "safety" as I'm annoyed with it. If I go anywhere out of my general neighborhood, I do buckle up. I'm not stupid and like that saying goes, "because the life you save could be your own!"....
Speaking of .45acp... Does anyone make any center console mounted in pistol safes FOR these SUV's? Guess that's for another topic!
Old 02-17-2011, 12:36 PM   #6
backfrmcolorado
Commerce Twp, MI
'94 Eddie B explodwhore
Vehicle Specs
Quoted: 1 Post(s)
it dosent matter the reasons, buckel up! We dont want to lose another dear friend on this site.
RIP John Rock
__________________
1994 Eddie Bauer Explodwhore Grn/tan.
Nickname (GOLD DIGGER)
http://i985.photobucket.com/albums/a.../SUNP00381.jpg
1992 XLT Exploder 4inch lift w/31s
Nickname (Ticking Timebomb)
backfrmcolorado is offline   Reply With Quote
Old 02-17-2011, 01:03 PM   #7
reapereviltwin
Keep on wheelin John Rock
Jonesboro, Tx
reapereviltwin's Avatar
'92 Explorer
Vehicle Specs
Quoted: 47 Post(s)
Quote:
Rip john rock
x2 !!
__________________
HELL YES I'M AN AMERICAN. I HAVE SERVED MY COUNTRY, NOW I AM GOING TO SEE THIS LAND!!!
The "Dr. Jack"
http://www.explorerforum.com/forums/...d.php?t=257885
Demon4x4.com
reapereviltwin is online now   Reply With Quote
Old 02-17-2011, 01:05 PM   #8
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 99 Post(s)
I'd just put on the seatbelt. I wear it no matter what speed I'm driving because without it, it doesn't feel right.
My cousin and two friends passed away because they didn't have their seatbelt on. My sister's truck got hit in the rear, knocked it onto it's side and she was fine because she was wearing her seatbelt. Without it, she would have been hurt pretty bad.
I've been in two major wrecks(I wasn't driving). The worst was a few years ago in Mexico. It was dark, just stopped raining and we where headed back to the dorms. I was in the center of the first passenger seat(Ford E350) and we had another van in front that we were following. Going around a corner at 60mph, an oncoming car was in the wrong lane and swerved to miss the first van, overcorrected and got sideways and BAM, we t-boned him.
If I didn't have my seatbelt on, without question I would have been through the windshield and possibly not here today. So just wear your seatbelt because you never know how another driver will act.
__________________
"Spending money I don't have, on parts I don't need, to impress people I don't know"
Sold 12/31/2015 - 2002 4.6 4x4, K&N CAI, Henson tuned, FM70 and 20" Boss 306's
Limited02 is offline   Reply With Quote
Old 02-17-2011, 01:45 PM   #9
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
I agree! Buckle up all the time, every time. Thinking that because you are close to home and in a 25MPH zone that you don't need your seatbelt is, at the risk of sounding offensive, just plain ludicrous!!
My response to the poll "Do you wear your seatbelt?":
Quote:
Originally Posted by BigRondo View Post
Every time, all the time. Even just moving the car out of the driveway. The seatbelt gets clicked before I shift into gear.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 02-17-2011, 02:18 PM   #10
JCR
Lancaster, Pennsylvania
2002 XLS
Vehicle Specs
Quoted: 5 Post(s)
You do realize that two cars that collide going 25 mph in the opposite direction is like hitting a wall doing 50 mph? I have been a career firefighter for 28 years now and have never had to unbuckle the seat belt of a dead person. Think about!
JCR is offline   Reply With Quote
Old 02-17-2011, 02:25 PM   #11
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
kd- just in case you think everyone is piling on, we do tend to have a slight pile-on for safety issues, but it's doing to be amplified right now since we just lost one of our most dear members and moderators to an accident/vehicle ejection. It's a touchy subject right now...
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 02-17-2011, 02:34 PM   #12
synyster
Hammond IN
'02 Limited V8
Vehicle Specs
Quoted: 3 Post(s)
like the billboards say all along I80/94, "click it or ticket"..can never be to safe now-a-days.
synyster is offline   Reply With Quote
Old 02-17-2011, 02:53 PM   #13
Doomstang
St. Louis, MO
02 XLT and '91 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
While I agree 110% that you should always wear a seatbelt (I always do), I just had to correct this since it is a very common misconception. Two cars going 25mph that collide head on is NOT like hitting a wall doing 50 mph. The physics show that it is actually like hitting a wall at 25mph...for each party.
Mythbusters did an episode on this after Jamie had made a comment similar to yours on a previous episode. He admitted he was surprisingly wrong after doing tests with crashing Car A into a wall at speed X, Car B traveling into Car C (each traveling at speed X), and then crashing Car D into a wall at speed 2X.
Cars A, B, and C all sustained very similar damage while Car D sustained much worse damage (thus busting the myth).
PS: Thanks for your work as a firefighter, it is much appreciated!
Old 02-17-2011, 03:07 PM   #14
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
I saw that episode and was surprised by the outcome but it makes sense
As for the seat belt chime, I wear my seat belt all the time.
But I hate that chime if I start to move and I don't have it on.
So I disabled mine. Its one of the first things I did to my 3rd gen.
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
Curtis is offline   Reply With Quote
Old 02-17-2011, 03:43 PM   #15
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
that experiment is true for cars of the same type. What i think they didnt factor and calculate is the deformation as absorption of energy. As such, running a car at 25mph into a big loaded truck going 25mph going the oppsite direction will result in very different force and energy readings from those in the show - which is obvious since something like a brick wall will not deform very much and almost all of the energy will have to be absorbed by the car and anything else in it. This is one of the foundations in the safety of sedans vs SUVs. While its true that survivability in an SUV is greater than a sedan, there will always be a bigger fish in the pond with more mass and a stiffer chassis.
So yes while you may survive a crash against another sedan at 25mph with no seatbelt, you may not be so lucky if that sedan going the opposite direction isnt actually a sedan but rather a loaded F-350.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 02-17-2011, 04:02 PM   #16
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
The physics of the whole thing is very interesting. But one question remains. Who wants to hit a brick wall at 25 MPH? 25 MPH seems very slow when you are driving but it's a completely different story when you are hitting a brick wall. Here is a video of the Seat Belt Convincer. It simulates a crash at 5-7 MPH. I had the opportunity to try one of these way back when I was in high school. 5-7 MPH isn't as gentle as you may think.
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
__________________
Old 02-17-2011, 04:08 PM   #17
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
i think that's easy enough to answer : not many people. Thats why its called a car "accident" - that is to say, its probably not intentional (or nobody "wanted" it to happen) regardless of seatbelt or no seatbelt.
__________________
Old 02-17-2011, 04:13 PM   #18
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Exactly. You don't when it's going to happen, how it's going to happen, or why it's going to happen. The moral of the story is always wear you seatbelt!!
__________________
Old 02-17-2011, 04:13 PM   #19
FirstOnRaceDayy
Cobleskill NY
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
think about it like this. your doing 25, the car coming at you is doing 25, and you hit head on. pretty much the same as hitting a stationary wall doing 50 and your going through the windshield.. just put the seat belt on.
__________________
1998 explorer XLT 4.0 OHV. TT, shackles, 3in. body lift, 3.73s, 33s.
FirstOnRaceDayy is offline   Reply With Quote
Old 02-17-2011, 04:14 PM   #20
fedyfedz
Suffolk County, NY
2002 limited v8
Vehicle Specs
Quoted: 4 Post(s)
unfortunately i totateld my last truck doing about 7-8 mph and hit ice and sped up to 15mph i hit 2 trees and i didnt have my seatbelt on...im lucky to survive i had 2 other people in the car and the person sitting in the back seat in the middle ended up in the front seat, I was knocked unconscious for 10 min. just look at the truck.....had no collison either
this is what 10-15 mph and some trees do
__________________
*Registry*
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
