seat belt chime will not stop 05' mountaineer | Ford Explorer Forums - Serious Explorations
lecky204
nyc
05 merc mountaineer
How do i deactivate the seat belt chime on an 05 mountaineer, until I can fix or replace the belt. The seat belt sensor does not recognize that it is closed.
I moved your thread to the "Stock 2002-2005 Explorer" forum.
Welcome to our site:chug:
I don't remember who posted this originally so i can credit them, but here it is:
Belt Minder Deactivating/Activating
Preparation
1. Before deactivating/activating the belt minder, set the parking brake.
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
1. Turn the ignition switch to the RUN position. (Do not start the engine.)
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete.
Sorry, I stand corrected. Some ST manuals said nine clicks and didn't work, where three actually did. :thumbsup:
