Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Help Changing Rear Differential Fluid
Reply
Thread Tools
Old 05-27-2011, 11:57 PM   #1
KPPCExplorer
Kings Park, New York
2002 XLT V6
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I'm looking to change my rear differential fluid. Just did my transfer case fluid with no problem. I know the differential is supposed to be sealed for life, but I do some off roading and definitely submerged it dozens of time. Not to mention I now have almost 145,000 miles and would like to get fresh oil in there.
Now, I see the 3/4 inch drain hole, and there's a plug directly above it that's 3/8, but I don't believe that's the fill plug. I read on the forums that the fill plug is 1/2 inch, but I don't see it on the axle anywhere. It's a little tight in there, so maybe I'm just missing something. I watched the thread on how to change the fluid a dozen times under the differential/transfer case/transmission section, but that was from a older generation explorer and ours look a lot different back there. Does anybody know where the fill plug is on the rear differential? Thanks.
KPPCExplorer is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-28-2011, 12:09 AM   #2
xlt03
Bay Point, CA
2003 XLT 4.6 4X4
Vehicle Specs
Quoted: 19 Post(s)
The fill plug is 3/8" and drain is 1". In case you didn't see other posting on fluid change, start with actually loosing the fill plug first. You want to make sure you can put fresh oil in afterwards. After confirming that the fill plug can be removed then drain the diff. Also use some teflon tape on the plugs so you don't get seepage. If yours is a LS don't forget the friction modifier.
It'll take just about 2 quarts.
xlt03 is offline   Reply With Quote
Old 05-28-2011, 12:09 AM   #3
gamecocks
Greenville, SC
gamecocks's Avatar
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Mine fill plug is 3/8 your on the right one
__________________
K&N 57series 2537 FIPK : Truxx spacers 2.5" : 285/75 Cooper STT : 16"x8" ION 171 4.25 BS, -6offset : Rola Roof Rack, 4 Hella 500 : Body Lift 3" : Flowmaster Delta 40 : F150 Tow Hooks
gamecocks is offline   Reply With Quote
Old 05-28-2011, 05:18 AM   #4
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
You can also get a little hand pump thing for 10 bucks that will let you stick a small hose into your bottle of gear oil and the other hose into the fill plug hole. Makes it easier than dealing with the tricky angle with the fill hole and trying to tip a bottle up in there.
Ronin8002 is offline   Reply With Quote
Old 05-28-2011, 07:46 AM   #5
patrick112390
chesterfield,va
97' mountaineer 5.0 4406
Vehicle Specs
Quoted: 0 Post(s)
make sure you over fill it a half quart after it starts dripping from the fill plug...
__________________
97' mountaineer 5.0 V8 4406- k&n intake, hunter brush guard, front/rear tow hooks, 35X14.50 Mud Grapplers, crager soft 8 rims, remote start, shackles, TT, AAL, 3'' pa body lift, 4'' superlift, 4406 swap, 4.88 gears and a full carrier Detroit Locker
patrick112390 is offline   Reply With Quote
Old 05-28-2011, 12:36 PM   #6
Wade99
Palm Harbor, FL
99
Vehicle Specs
Quoted: 0 Post(s)
Quote:
What he said!
Wade99 is offline   Reply With Quote
Old 05-28-2011, 01:08 PM   #7
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 101 Post(s)
+2
This will make the job much EASIER and CLEANER!!!
__________________
"Spending money I don't have, on parts I don't need, to impress people I don't know"
Sold 12/31/2015 - 2002 4.6 4x4, K&N CAI, Henson tuned, FM70 and 20" Boss 306's
Limited02 is offline   Reply With Quote
Old 05-28-2011, 04:25 PM   #8
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Quote:
The fill plug is the smaller plug hole at the top and the larger, lower plug is for draining the rear diff. There is plenty of room to get the plugs out, approx: 2 inches or so of clearance. The rear diff on my 2005 Explorer uses Mobil One full synthetic 75W-140 gear oil according to the Haynes manual, not sure if yours is the same. The stuff isn't cheap (liquid gold), I paid $18.99 per quart(buy 2) and it should take 1.60 to 1.75 quarts depending on which diff you have. If you do have a Limited Slip differential, add 4 ounces of Friction Modifier as well. It comes in a 7 ounce squeeze tube. A hand pump works good to fill up the diff. If you have an Advance Auto Parts store near you, order all the stuff online and pick it up at the store and use their coupons from Coupon Cabin.com. You can get $20 off a $50 dollar order and your order will come close to that amount for this job. If you need extra elbow or head room under the rear end, remove the spare tire. It's not hard to do.
Exproblems is offline   Reply With Quote
Old 05-28-2011, 06:02 PM   #9
KPPCExplorer
2002 XLT V6
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I know how you do it and what you put in, I'm just trying to make sure I got the right fill hole before I go and open it and find out it's not the fill hole and I now can't drive my car. I thought the fill hole was usually on top of the differential, but this one is just over half way up.
I took a picture of my differential. Could somebody confirm if this is correct? Thanks.
Old 05-28-2011, 06:15 PM   #10
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 101 Post(s)
CORRECT!!!
Now get to work
__________________
Old 05-28-2011, 06:31 PM   #11
KPPCExplorer
2002 XLT V6
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I most definitely will. Thanks Limited!
Old 05-29-2011, 08:37 AM   #12
stuartr
Richlands, VA
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 1 Post(s)
So what do you use to take that huge plug out? I thought about doing mine but didn't have anything to take it out with.
STU
__________________
Mountianeer family I have a 2002 and she has a 2008. Both AWD V6.
stuartr is offline   Reply With Quote
Old 05-29-2011, 08:39 AM   #13
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 127 Post(s)
You need to buy a 3/4" socket adapter that will fit on a 1/2" drive ratchet or breaker bar.
Old 05-29-2011, 09:29 AM   #14
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 101 Post(s)
DING DING DING, we have a winner!!!
This is the same thing I did.
__________________
Old 05-29-2011, 04:05 PM   #15
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quoted: 85 Post(s)
>>>>>>>>>>>>>[QUOTE=KPPCExplorer;2738350] I thought the fill hole was usually on top of the differential, but this one is just over half way up.
I took a picture of my differential. Could somebody confirm if this is correct? Thanks.>>>>>>>>>>>
If the fill hole was on top of the diff housing, you need a hell fo alot of gear oil to fill it up and that would be overkill. Approx half way up the housing is correct for a diff fill hole, just enough oil to keep half of the gears submerged in oil and well lubricated through the splashing, blender like motion of the gear teeth spinning through the oil as the vehicle moves. You'll see it is an easy job. FYI, I stopped at one of those quick oil change places and was quoted $100 + tax to change out that gear oil in the rear diff. I looked at the guy and said you must be $hitting me! I was thinking more like $39 till he told me about the "liquid gold" oil it needed. Doing it yourself and using the discount coupons I mentioned if you can, you'll save yourself approx. $65 + the tax "differential".
Old 05-29-2011, 10:45 PM   #16
KPPCExplorer
2002 XLT V6
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Well I did it today and it was very easy. Cost me $38 for 2 quarts of oil and $7 for a 1/2 inch to 3/4 inch drive adapter. Used a suction gun to put the new fluid in and it's good as new. The old fluid was definitely dirty and needed to be changed. Thanks for the help guys.
Old 05-30-2011, 04:06 AM   #17
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quoted: 85 Post(s)
Glad to hear it went well for you. Just think, 5 quarts of that "liquid gold" gear oil you just bought, costs the same as a 55 gallon drum of crude oil.
Old 05-30-2011, 10:40 PM   #18
fusseli
2002 4.6L
Vehicle Specs
Quoted: 4 Post(s)
I did my front and rear diffs at 122k, the rear was black and the front was even blacker and sludgy. Pretty sure diff oil needs to be changed more often than that. For some reason a 60k or 75k interval rings a bell?
For anyone else looking for ideas, I opted for a 3/4" drive breaker bar for $20 at a ranch supply store. My 1/2" bar bends at the joint quite a bit at 200ftlbs (changed a AWD/4WD front wheel hub yet?) so it couldn't hurt to have a much thicker bar and an adapter down to 1/2" for future projects :p The 3/4" plug on the rear diff wasn't that hard to remove. Haynes says 25ftlbs for the "check/fill plug" and nothing for the drain plug. Also, I drained into a normal oil changing pan and used a hand pump to pump new fluid. Dumped the LS friction modifier into the first bottle and shook it up then resumed pumping.
fusseli is offline   Reply With Quote
Old 06-01-2011, 09:43 AM   #19
DVRDOWN
West Palm Beach, FL
'02 XLT Flex Fuel 4x4
Vehicle Specs
Quoted: 0 Post(s)
Has anyone pulled the rear diff cover off to drain the fluid/clean out and inspect the gears etc. like you would do on a normal Dana 44 etc? I need to change my fluid, but after driving at highway speeds for awhile, i am getting a very distinct grinding feeling while turning as if all the oil has spun off the gears, but after sitting/slow speed driving around town it returns to normal. I want to pull the cover off and check for metal shavings etc. when i change the fluid but am wondering if its a major PITA...
__________________
2002 XLT 4x4 4.0 Flex, 115K miles
DVRDOWN is offline   Reply With Quote
Old 06-01-2011, 10:23 AM   #20
gamecocks
Greenville, SC
gamecocks's Avatar
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I havent done it but it kinda looks like itd be a pain, the top bolts are hidden by a cover type deal
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
