#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Water leak (Back motor driver side)
Reply
Thread Tools
Old 06-05-2011, 09:37 PM   #1
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok guys I've been fixing up my 1997 explorer 4wd sohc v6. I changed our sway bar bushing and endlinks. Took it for a test drive and look down and it says check gauge I look and the water temp is on H not in red but on the H 12 o clock. So I said hmm Never had cooling issues besides changing out water pump 2 months ago. Then the gauge goes down to maybe 10 o clock. Then shoots back up 1 minute later and plays this game as I limp home.
I let it sit and figure its the thermostat being a pain so I bought a new one and replaced. Then start it up and gauge is still reading hot. So I shut off and disconnect battery thinking gauge was stuck or something. So I turn her back on after 5 mins of battery re set.
Still same problem then I notice water dripping under car I figure, eh I let some spill its running down since car is on and vibration moves water.
Then I back her up and re check. I notice water dripping from the front trans bell housing on driver side ( my car leans driver side) So I look and try to find the leak and find nothing and its coming out pretty good now.
Any cooling lines around there? I hope its not freeze plug :-( Any ideas guys?
Thanks
Racingtheburg is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-05-2011, 09:53 PM   #2
1998Exp
Seattle WA
98 Limited V8 AWD
Vehicle Specs
Quoted: 115 Post(s)
Not familiar with the V6 to tell you if there are any potential leak sources on the rear of the engine -- perhaps a freeze plug in the cylinder head. SOHC experts, please chime in...
However, the point from which coolant drips down is often nowhere near the source. It may be leaking at the front and making its way to the back over top of the intake manifold, over the oil pan lip, etc, etc. You may be lucky and see the leak if it's large, or follow it by the green deposits. Otherwise the best way to find the source is to hook a pressure tester to the radiator with the engine cold and carefully look around with a flashlight and mirror. The next best may be to use a fluorescent dye.
Thanks
1998Exp is offline   Reply With Quote
Old 06-05-2011, 11:29 PM   #3
corkey
Moderator Emeritus
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
corkey's Avatar
99 xls,96 xl,91,08 Ranger
Vehicle Specs
Quoted: 90 Post(s)
okay, i had this too, answer to the question is, yes, the leak is on the back of the engine, and no it is not a frost plug,
It is the lower intake gasket , like this ,,
it is a fairly involved process to change these, might have to be a done at a shop Job,,
corkey is online now   Reply With Quote
Old 06-06-2011, 09:09 AM   #4
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Do you have a diagram of cooling system?
Also I don't mind I build engines and tinker on cars all the time. This explorer is just a very tight fit in the back hard to see. Makes sense might as well change it truck is about to turn 100k miles.
I will check tonight thanks for the post. Do you have a write up on the install?
Thanks
Old 06-06-2011, 09:19 AM   #5
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Found this: http://www.ford-trucks.com/forums/23...ke-gasket.html
Trying to find the gasket first just in case if I need it. Advance auto not pulling it up weird...
Old 06-06-2011, 10:18 PM   #6
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Part numbers for lower intake gasket?
Old 06-08-2011, 10:55 AM   #7
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Anyone?
Old 06-08-2011, 12:10 PM   #8
Dono
V8 Limited and SC 4.0 OHV
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 412 Post(s)
No, Ive only done the 4.0 OHV. Maybe look on rockauto.com. You can also use a discount code on this site.
__________________
00 Limited V8 rear mount turbo http://www.explorerforum.com/forums/...d.php?t=388599
and a Rebuilt SC 4.0 OHV.
Dono is offline   Reply With Quote
Old 06-14-2011, 10:43 PM   #9
corkey
Moderator Emeritus
corkey's Avatar
Vehicle Specs
Quoted: 90 Post(s)
what engine is in your Explorer?
that will help us out a ton,
Old 06-15-2011, 06:39 AM   #10
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Its in my first post? 1997 4.0l sohc v6
Old 06-15-2011, 10:20 AM   #11
Dono
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 412 Post(s)
Im confused. The picture at rockauto.com of the lower intake gaskets do not look at all like the picture you posted.
What you posted looks like my 4.0 ohv motor.
http://www.rockauto.com/catalog/moreinfo.php?pk=446672
Are you sure you have the SOHC?
Here's the lower intake gasket: http://www.rockauto.com/catalog/moreinfo.php?pk=447113
With the valve covers off, do you see rocker arms?
__________________
Old 06-15-2011, 10:27 AM   #12
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Wasnt my picture above. Also from what I have read it might be frost plug.
Are there any water hoses behind engine in that area>? Also possible heater core or hose?
I can't find hose diagram anywhere.
Thanks
Going to tear into it Friday to get a better look.
I'm 100000% positive mine is a SOHC
Old 06-15-2011, 10:34 AM   #13
Dono
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 412 Post(s)
Sorry, I cant help on this. We need an SOHC guy to chime in.
__________________
Old 06-20-2011, 09:58 AM   #14
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok so i am the idiot here.
I check the leak further and took off top of intake to see if maybe...just maybe the thermostat housing was leaking in the back. You guessed right...it was! Big time! And couldnt see it unless top intake was off (which makes doing a thermostat 10 tiems easier!
So I RTV the housing of the thermostat no leaking and runs great. I must of fixed a intake line because the idle is a little better lol. I did notice I need to change the PCV.
Old 06-20-2011, 11:21 AM   #15
Dono
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 412 Post(s)
From what I keep seeing, the SOHC is a bit more involved with anything that needs fixing than the OHV. The SOHC is a more efficient motor though. Great to see you fixed it yourself.
__________________
Old 06-20-2011, 11:26 AM   #16
Racingtheburg
St. Petersburg, FL
1997 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Yea it is a little crammed but doable. Just pay attention to where things went and go lol.
BEST ADVICE ON HOSES AND WIRES. Take GREEN bright GREEN painters tape and wrap around each side of connection so thats 2 pieces of tape one for one side and another for the other of where it plugs in. THEN label each tape side with permanent marker. Use 1,2,3,4 or ABCD. Example:
You have an intake hose that goes on intake. Tape the end of hose that plugs into intake and tape intake area where hose plugs in. Then on each piece of tape label it A and A on the other so you know where it goes.
Old 01-11-2014, 12:30 AM   #17
auctionaddict
Capistrano Beach, California
2001 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Thanks, 1st time on, my 01 4.0 shoc appears to have the mystery leaking lower manifold.
auctionaddict is offline   Reply With Quote
Old 01-11-2014, 01:00 AM   #18
rb142
Detroit, MI
2001 Ranger XLT 4X4
Vehicle Specs
Quoted: 134 Post(s)
I was going to suggest checking that thermostat housing, because they are known to leak and the coolant can easily run across the top of the block and down the back. The gauge problem was probably just because the coolant level had dropped enough that the coolant temp sensor was out of the water -- sloshing would move the reading.
It's always nice when it ends up being one of the cheaper and easier to fix possibilities.
rb142 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
