- January 12, 2012
- Geelong, Australia
- 98 Explorer XLT SOHC
Hi all,
My air vents are stuck on "defrost" mode no matter what the selector is set to.
So I need some advice reguarding the thin hard plastic vacuum line that runs from the "ball accumulator" into the fire wall and then on to the airvent actuator.
It appears that there is a blockage in the line somewhere between the connector on the outside of the firewall and the connector on the inside of the fire wall. Is this normal? say from a valve somewhere that I haven't seen yet or is this the blockage that is causing my vents to stay on "defrost" mode?
It's hot as hell out here during the day and I really miss the air con blowing ice out of the vents. Any advice in reguards to this no matter how trivial it may be would be greatly appreciated.
I Thank you in advance, Luke...
