Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How To: Remove/Replace 3rd Gen Center Console
Reply
Thread Tools
Old 07-07-2012, 11:11 AM   #1
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
This is my how to for removing & replacing the center console on the 3rd Gen Ex.
Be Sure To Check Out My Other Write-Ups:
How To: Replace Blend Door Actuator in 3rd Gen Ex
How To: Remove/Replace 3rd Gen Door Panel
How To: Install Signal Mirrors On 3rd Gen Ex
How To: Restore Faded, Yellowing Headlights
How To: Replace Multifunction Switch in 3rd Gen Ex
How To: Paint Rear Pillar Trim
How To: Replace 3rd Gen Ambient Air Temperature Sensor
How To: Test a Relay
Tools Required:
1. 7MM Socket
2. 8MM Socket
3. Ratchet
4. Large Slotted Screwdriver
5. Butter Knife of Putty Knife
Center Console Removal & Replacement Detailed Instructions:
1. Remove Center Console Upper Half
1.a. Remove rubber mat
1.b. Remove screw under mat – 7MM socket required
1.c. Pry from rear and pull out console upper half
1.d. Disconnect front power point connector & extra power source connector (Cigarette Lighter?)
1.e. View with upper half removed
2. Remove Center Console Lower Half
2.a. Disconnect rear power point connector
2.b. Pop off rear power point connector with screwdriver – be careful not to damage connector
2.c. Pop off harness with screwdriver – be careful not to damage any wires
2.d. Remove 2 front screws – 8MM socket required
2.e. Remove 2 duct screws – 8MM socket required
2.f. 4 top screws remain in place
2.g. Remove passenger side rear screw cover – butter knife or putty knife required
2.h. Remove passenger side rear screw – 8MM socket required
2.i. Remove driver side rear screw cover – butter knife or putty knife required
2.l. Remove driver side rear screw – 8MM socket required
2.j. Pull passenger side front of console away from center and toward door to disengage velcro
2.k. Pull driver side front of console away from center and toward door to disengage velcro
2.l. Lift console lower half up and out of vehicle
Removal of Center Console is Complete!
Replace Center Console
3. Reinstall Center Console Lower Half
3.a. Set console lower half back into place
3.b. Push console forward to close gap in lower duct
3.c. While pushing console forward, Install passenger side rear screw – 8MM socket required
3.d. Replace passenger side screw cover
3.e. While pushing console forward, Install driver side rear screw – 8MM socket required
3.f. Replace driver side rear screw cover
3.g. Install 2 duct screws – 8MM socket required
3.h. Install 2 front screws – 8MM socket required
3.i. Push passenger side front of console toward center to engage Velcro
3.j. Push driver side front of console toward center to engage Velcro
3.k. Push harness back into place
3.l. Push rear power point connector back into place
3.m. Connect rear power point
4. Reinstall Center Console Upper Half
4.a. Connect extra power source & front power point
4.b. Set console lower half back into position and push downward to snap into place
4.c. Install screw – 7MM socket required
4.d. Replace rubber matt
Center Console Removal & Replacement is Complete!
Thanks for looking
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is online now   Reply With Quote
Old 07-08-2012, 06:55 AM   #2
Triton8273
B
Vehicle Specs
You just do this one for fun? lol
EDIT: NVM lol, just realized these are from the blend door thread
Triton8273 is offline   Reply With Quote
Old 07-08-2012, 08:02 AM   #3
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
You are correct!! I figured instead of telling people to check out the BDA thread, they could check out the console thread.
__________________
Reply
Tags
center console, console
Similar Threads
Thread Thread Starter Forum Replies Last Post
How To: Install Signal Mirrors On 3rd Gen Ex BigRondo Performance Lighting 81 05-20-2013 04:00 PM
2nd gen console removal Turdle Explorer - Ranger Interior Accessories 64 04-05-2013 09:12 AM
3rd Gen Gauge Cluster LED Bulb Swap solved! tgrfly Modified 2002 - 2005 Explorers 24 01-12-2013 01:26 AM
Husky 3rd row / 2nd console update blwnsmoke Modified 2011 + Ford Explorer Discussion 35 05-13-2011 04:18 PM
3rd Gen Center Arm Rest Lid Repair jsbatch Explorer - Ranger Interior Accessories 0 07-31-2010 11:28 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
