| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
How To: Remove/Replace 3rd Gen Door Panel
I have not found a thread for specifically removing the door panels. When someone asks, I usually point them to a thread that involves removing the door panel but is not specifically for removing the door panel. Hopefully this will eliminate any confusion.
Be Sure To Check Out My Other Write-Ups: How To: Replace Blend Door Actuator in 3rd Gen Ex How To: Install Signal Mirrors On 3rd Gen Ex How To: Restore Faded, Yellowing Headlights How To: Replace Multifunction Switch in 3rd Gen Ex How To: Paint Rear Pillar Trim How To: Replace 3rd Gen Ambient Air Temperature Sensor How To: Test a Relay How To: Remove/Replace 3rd Gen Center Console Tools Required: 7/32" Socket Butter Knife, Putty Knife, or Trim Removal Tool ![]() 1. Remove Door Panel 1.a. Remove Both Bottom Screws - 7/32" Socket Required ![]() 1.b. Remove Interior Door Handle Cover - Use butter knife, putty knife, or trim removal tool to pry up front of cover then remove ![]() 1.c. Remove Window/Lock Switch Assembly - Lift up at point indicated by red arrow ![]() 1.d. DRIVER'S SIDE - Remove Electrical Connectors - Press in tabs indicated by red arrows. I used the small slotted screwdriver to remove the green connector because I couldn't access the tab with my thumb ![]() 1.d. PASSENGER'S SIDE - Remove Electrical Connectors - Press in tabs indicated by red arrows. ![]() 1.e. Remove Arm Rest Screw - 7/32" Socket Required ![]() 1.f. Lift Door Panel Up And Towards You No Picture. I couldn't remove door panel and take a picture at the same time 1.g. DRIVER’S SIDE ONLY - Disconnect Electric Mirror Adjustment Switch ![]() 6. Replace Door Panel 2.a. DRIVER’S SIDE ONLY - Reconnect Electric Mirror Adjustment Switch - Snap connector back into mirror switch ![]() 2.b. Replace Door Panel on Door – Line Up Mounting Pieces to Holes in Door & Slide Down Into Place No Picture. I couldn't replace door panel and take a picture at the same time 2.c. Replace Arm Rest Screw - 7/32" Socket Required ![]() 2.d. PASSENGER'S SIDE - Reconnect Window/Lock Switch Connectors - Snap connectors into switches ![]() 2.d. DRIVER'S SIDE - Reconnect Window/Lock Switch Connectors - Snap connectors into switches ![]() 2.e. Replace Window/Lock Switch Assembly - Place back side in first and gently push down ![]() 2.f. Replace Interior Door Handle Cover - Set back side in first and gently snap cover into place ![]() 2.g. Replace Both Bottom Screws - 7/32" Socket Required ![]() You are done!! __________________ Quote:
#2 | |
Living in Greenland
Holland, MI
'00 V8 XLT
Well done!
I was just thinking that as I typed the description for the GII last night. BTW- I fixed your last step with a tallboy... ![]()
#3 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
It's like it was made for a can of PBR!!
![]() I read your description for the 2nd Gen. Gonna need that when I install the keypad. Couldn't find a write up for that. Looks like I know what my next one will be. __________________ Quote:
#4 | |
Living in Greenland
Holland, MI
'00 V8 XLT
I was just thinking that... I was going to do one, but you have to put the keypad in too...
#5 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
Might as well do it since I'm going to be knee deep in it.
#6 |
Wannabe Elite Explorer
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Does the pattern of the silverware (knife) matter, or can I use sterling, silver plate, or stainless steel flatware?
__________________ Wife's: '02 Limited 4.6L/4x4 Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe |
#7 | ||
USMC 1371
Worcester, MA
2002 XLT V6 4x4
#8 |
Hmm.... Jeeps or Fords?
Ogden, UT
1998 XLT V6
Great write up Rondo!
I found that my arm rest bolt was a different size than the rest. The two on the lower door were 8mm and the arm rest was a 6mm. EasyRhino; you can always make a trip to Harbor Frieght Tools and get a set of cheap panel pullers. __________________ Nate H 1998 Ford Explorer XLT 4.SLOW Restoration Project - OEM Restoration with larger than stock tires. 2004 Jeep Grand Cherokee Laredo - 3.5" Lift, Quick Disconnects, Rear Locker, Mopar Off Road Package, Gray Moab Wheels, Differential Skid Plates, and much more!
#9 | ||
USMC 1371
Worcester, MA
2002 XLT V6 4x4
Quote:
I think EasyRhino was just having some fun with me about my "tools" aka butter knife! __________________ Quote:
#10 |
Kailua, Hawai'i
My wife would kick my butt if I used her flatware!
![]() But I have considered buying one of those trim removal tools thingees. A very apt and well done post, as these door panel removals are kind of anti-intuitive. A sticky perhaps? I have seen repeated posts over the years asking how to do this. __________________ Wife's: '02 Limited 4.6L/4x4 Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe |
#11 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
My flatware, my rules.
![]() I thought the same thing about the question being asked all the time so I did the write-up. I'm going to be changing the keypad on my nephew's '98 soon and will do a write-up for the 2nd Gen door panel as well since one doesn't exist. __________________ Quote:
#12 |
Kailua, Hawai'i
#13 |
Newman Lake, WA
98 XL, 03 XLT
Door panel Removal
I have found that a flat pry bar with the nail slot works good. Commonly called a "Wonder Bar". Otherwise the nylon push fastener pulls out of the slot/hole in the door panel.
When I worked as a dealership tech the lube guy took a window track job because I was busy. He didn't see the screws hidden by the carpet on the door panel. He forced the door panel off with a BIG pry bar. OUCH! He then asked me how to get the track out and I remarked "WHAT DID YOU DO TO THE DOOR PANEL!" LOL. The shop had to buy a new door panel. Last edited by garmstrong2007; 03-03-2011 at 12:09 PM. Reason: Spelling and grammar |
#14 | ||
USMC 1371
Worcester, MA
2002 XLT V6 4x4
Quote:
![]() The 3rd Gen doesn't have any "Christmas tree fasteners" on the door panels. __________________ Quote:
#15 |
Newman Lake, WA
98 XL, 03 XLT
OH, OK, so what does it use? I have to work on the one I'm getting on Wednesday and like to know so I don't break something. Thanks.
#16 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
Start at the top of this thread. This is the how to on removing/replacing the 3rd gen door panel.
#17 |
CT
2004 ford explorer
Thanks clarabow
#18 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
Welcome aboard!!
![]() You are welcome. Glad I could help out! ![]() __________________ Quote:
#19 |
Roseann VA
2002 Explorer Limited 4.6
Finally I was able to purchase and install the Mirror switch. Much THANKS to BIG RONDO for posting the link to the info about the removal of the door panel. Only one thing I would add or clarify to the info. I am old school and used to the type of panel connectors that pushed into holes in the door frame. When the author stated "pull up on the door panel" my mind converted pull up to pull out I guess and I tried and tried to gently pry out on the panel to pop loose what I assumed were the push in connectors with no luck obiviously. My bad for not understanding up means up and does not mean pry out but to clarify this for anyone else "up means up." The door panel has downwarrd facing L shaped hook fasteners that slide down into slots in the door frame so don't attempt to pry outward, just lift the panel straight up toward the top of the door frame, out of the slots and window frame. It is actually much easier than the old push in type fasteners that used to be the norm. Other than that the info in here is spot on every step of the way.
BTW the engineer that designed the way that the switch for the door lock installs in the panel with the window controls must have never removed or installed an electrical connector in his life or he wouldn't have placed the locking tab between the switch and the connector tab that holds the panel in the arm rest. It is extremely hard to release the lock on that conector but with patience it will release just take your time and remember it is plastic do not force it! |
#20 | |
USMC 1371
Worcester, MA
2002 XLT V6 4x4
Nicely done.
![]() This panel is so much easier to get off then other vehicles I've had. The switch for the door locks is a PITA!!! I remove the mirror switch from the door panel before removing the connector. __________________ Quote:
| Tags |
| door panel, door panel disassembly, door panel removal |
| Thread Tools | |
