- June 16, 2003
- Humboldt, KS
- 2000 Mounty
When I stomp on the gas and RPM"s exceed 3k, it sounds like a cat in trouble, but only when the EATC is set to "off". This has been "normal" for this truck since we got it.
Well, ok I switch between a couple functions and it stops the pathetic meow, it might do it on other settings.
The sound will occur even in neutral.Give her a good throttle blip and "sighmeowsigh" comes from the dash, behind the EATC control panel.
Has anyone encountered this?
I might add, when I first got this Mounty I used it to pull a trailer, and on one occasion during hard uphill acceleration the meow was followed by a CEL with a lean code. ( forget which one) but I replaced the fuel filter and have not seen this since, even while pulling a trailer.
