- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
After a deer took out my bumper and hood, which took out the radiator fan shroud which took out a fan blade and the radiator, I started looking into the electric fan conversion.
Pretty disapointing to say the least.
The best option seems to be the Lincoln Mark VIII due to CFM's. No aftermarket fans available new, so you're forced to buy off ebay or hunt through the wrecking yards. This is all fine and dandy until your used fan goes bad and the replacement could be days or weeks away.
So, a little research on some Ford vehicles that also have the 4.6l and below is what I've found.
Note: the specs came from Dorman, I added the pricing from NAPA.
Now you could buy these new, but also, this adds more options to the wrecking yard hunt. More seems like better in this case.
The DORMAN 620-119 (NAPA 855-3045, Retail $279.00, Crown Vic, Grand Marquis, Town Car 2006-2011) is a 2 speed fan. On low it draws 4 amps, on high it draws 20. The CFM’s on high are about 2700. (we do not have a low test rating on this one)
The DORMAN 620-130 (NAPA 855-2618, Retail $184.00, Mustang 1997-2000) is a 2 speed fan. On low it draws 16 amps, on high 30. The CFM’s are 2600 on low and 3100 on high
The DORMAN 621-353 (NAPA 855-2674, Retail $249.00, Crown Vic Police Interceptor/Taxi/Limousine 2006 - 2010) is a 2 speed fan. On low it draws 3 amps, on high 27. The CFM’s are about 1200 on low and 3200 on high.
