@makuloco2000 - Some great How To's | Ford Explorer Forums
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
I wanted to create a list of "how to's" by [MENTION=229411]makuloco2000[/MENTION]. He does some great videos on common repairs. He has a Youtube channel that you can subscribe to. If you watch his video's take a look at some of the ads so he gets credit for the work he's done.
Disclaimer: I have no affiliation with makuloco2000, other than I've subscribed to his Youtube channel.
Battery Draw Testing:
http://www.explorerforum.com/forums/showthread.php?t=399233
Bench Bleeding Brake Master Cylinder:
http://www.explorerforum.com/forums/showthread.php?t=398099
Blower Motor Only Works On High:
http://www.explorerforum.com/forums/showthread.php?t=409446
Checking and Adjust Trans Fluid Level 5R55S:
http://www.explorerforum.com/forums/showthread.php?t=396615
Cruise Control Inoperative Diagnose:
http://www.explorerforum.com/forums/showthread.php?p=3319443
Ford Power Steering Pump Teflon Seal Install:
http://www.explorerforum.com/forums/showthread.php?t=404166
Improved Front Hub and Bearing Replacement:
http://www.explorerforum.com/forums/showthread.php?t=402670
Load Testing Alternator On Vehicle:
http://www.explorerforum.com/forums/showthread.php?t=399270
Noisey (Noisy) humming noise front end (sic):
http://www.explorerforum.com/forums/showthread.php?t=393780
P2135 Throttle Position Sensor Replacement:
http://www.explorerforum.com/forums/showthread.php?t=402971
Resetting the PCM after Repairs are made:
http://www.explorerforum.com/forums/showthread.php?t=396533
Solenoid Pack Replacement 5R55S:
http://www.explorerforum.com/forums/showthread.php?t=396613
Trans Range Sensor Install No Special Tools Required:
http://www.explorerforum.com/forums/showthread.php?t=401665
2002-2005 Ford Explorer Rear Wheel Bearing Replacement:
http://www.explorerforum.com/forums/showthread.php?p=3356232
2002-2005 Instrument Cluster Removal Procedure:
http://www.explorerforum.com/forums/showthread.php?t=405633
2002-2010 Ford Explorer Temp Blend Actuator Removal:
http://www.youtube.com/watch?v=BERmZRDfqPw
4.6L & 5.4L Engines Alternator Replacement:
http://www.explorerforum.com/forums/showthread.php?t=402479
4.6L Power Steering Type Whine Noise:
http://www.explorerforum.com/forums/showthread.php?t=401147
5R55S Harsh Reverse & P0741 TCC Performance Valve Body Replacement:
http://www.explorerforum.com/forums/showthread.php?t=413221
Edit: 02-23-2016
2002-2005 Ford Explorer Door Ajar Light: Common Door Wiring (doors won't lock unlock from drivers side)
https://m.youtube.com/watch?v=egIGBzO065U
If I've missed any, let me know and I'll add them. Some of his solutions may be buried in the questions posted by others.
Wow thanks for this post and getting the word out. I may not have much time for the boards but I do now have many videos up (over 300) explaining how to fix some of the most common issues you guys are likely to run into.
Oh excellent thread!. Love your youtube channel Brian!. Hope you have more videos coming for current 2016 Explorers.
I like his videos, have been learning from them for a while now. Thanks very much!
I want to thank you for your videos. I know you are aware of how many views you get but hope you realize the impact you have made on those who watch. Your style is exactly what someone like me needs to have the confidence to tackle stuff that we normally wouldn't. I have started doing my own work on my Explorer, F150, and now a Jaguar because you demonstrate that it can be done. I never had done more than oil changes but have now changed struts, changed control arms, rotors, calipers, and pads ; sway end links ; spark plugs......etc... I am saving money but also having a great time doing my own work. Thank you very very much.
Agreed. I wasn't going to do the front wheel bearing hubs, but after watching the videos and reading up on it, I just did it myself. Great job on the videos!
