Savage Wolf
- October 2, 2000
- Mount Airy, Maryland
- '93 Sport v8 5.0
Wolf's '93 Sport Getting A '94 'stang 5.0 and 4R70W '99 v8 X tranny (Completed)
Pre-note, now that I have confused everyone with a name change, took me a while to find my real login seeing I forgot what it was in the 2 years since I had last used it
but I'm back!... now on with the show...
Ok, in the first thread I started (link here soon as I figure out how..) I was taking suggestions on what to use for the swap, well, now my mind is made up... and here is whats on it
Engine: '94 5.0lt EFI mustang motor, w/ all accories around 70k miles on it, need to get more info from the person I'm getting it from
-going with the '94 due to the shorter front for the much needed space in the X
Wiring:
Motor: '93 mustang harness, EEC-IV -going this route because of the EEC-IV adapts to mods much better then the post '94 computers
-going to wire the harness myself, that way its wired the way I want it, and run underhood the way I want
Trans: Baumann Engineering TCS, this unit will stand alone control the Aod-E/4R70W trans, unit using some of the EEC wiring for data to control the shift points and thottle kick down
-I dont think anyone else has gone this route, so I'll keep everyone up to date on how it works out
Trans/T-Case:
Trans: 4R70W, brand new '99 5.0 Explorer Trans *will not bolt up to the B/W 1350 t-case* also I dont know what the length is yet, still wating on them, if this trans is way over/under 29" overall its out and I'll be going with a Aod-E and a AA tailshaft kit
T-Case: Seeing that the 4R70W will not bolt up the b/w 1350 T-Case with out adapter, I'm looking to go with a Atlas T-Case, yeah it cost alot, but I'm already putting in a better motor/trans... why stop there *1 (see foot note)
Swap Adapters/kits:
This is the only part I cant make up my mind on =) I like the look of the L&L mounts, might end up going with duff for some of the other stuff also, I'll figure this out in the next 2 weeks
Overview: *1 (see foot note)
Reasons I have for going this route with this swap..
Well... I have a few reasons for going electronic with the trans, I really like the idea of being able to set the shift points, converter lockup, turning the OD on/off with a button. As for the hard parts of the trans, its a newer model year, parts should be easyer to find, from what i have heard its one of the stronger ones also, the lower gearing is a big plus, thats less $$ I need to spend on regearing the front and rear diffs untill I go over 31" tires and it should give the truck better highway/road performance. The T-Case... Atlas II 3.8:1 that speaks for itself
, few of the hidden advantages to the atlas t-case is I can pull the ford t-case control box out of my rear sail panel which would give enough room probably for a onboard air compressor....
More info and PICTURES! to follow (I would have pics of the duff 2.5" stage 2 install, but I didnt want to kill my digital cam)
FootNote!
*1- results may vary on a person to person basis
General Disclamer: Most info I have I have gathered in the last 2 weeks, most people wont agree with the Aod-E tranny, if ya dont like it, pay me way too much money and do the swap the way you think it should be done
All reasons and overview are my opinion, Please try not to spam this thread with flames
Wiring:
Trans/T-Case:
Swap Adapters/kits:
FootNote!
