Truck: 1997 Mountaineer, V8, 125k miles.
Problem: Truck will crank, but nothing else - no sputtering, no almost starting. Fuel pump can be heard to run for ~2sec when key is turned. No flooding smell regardless of how long it cranks.
This started several months ago as a very intermittent problem, and has now gotten to the point that I can't trust the truck to start when I need it.
Other important info: There is an intermittent check engine light. It is a soft code, it goes on and off on its own. It does not come on in any relation to the starting problem, although I don't doubt they are related. I just can't get the light to come on anywhere near a code reader.
No-start can happen when the engine is hot, just a little warm, or bone cold. Happens on hot days and cold days. Happens on flat ground and hills.
Inertial switch is not tripped. Pedal pumping doesn't help get it started.
I have been nursing this problem along by spraying ether into the intake when it won't start, which would cause it to immediatly catch and run on the next crank. This past week, that stopped working.
If the truck won't start, it needs to sit for anywhere from 2 mins to 2 hours before it will start. Truck has spark.
So I have a fuel problem. I can hear the fuel pump, so I do not suspect it or the fuel pump relay. What else can I check in the fuel system?
I am starting to think AFM or crank position sensor. Maybe the problem is not fuel getting to the engine, but that computer doesn't know that there is air coming in, or that the engine is cranking.
Any help appreciated. I need to fix this thing ASAP.
--Matt
--Matt
