Alakso
- September 20, 2011
- Maine
- 2000 Explorer 4x4
Just picked up a 2000 Explorer 4x4 auto for the Mrs that needs a steering column and shifter cable. I picked up a new shifter cable and a steering column from the junk yard. The junk yard steering column looks like the right one except that the PATS connector under the steering column that came in the Explorer is a white 4-wires in a row connector while the PATS connector on the junk yard steering column has a green 4-wire square connector. Is this the wrong steering column for this 2000 Explorer?
Also, will the PATS work if I use the ignition/keys that came with the truck if I put it in the junk yard steering column, or do I need to use the ignition/key that came with the junk yard steering column?
Thanks in advance!
Thanks in advance!
