Here is a copy of the tsb. Make sure you get the pcm reprogrammed while you get the radiator replaced. It contains some cooling system strategy updates.
Printable View (47 KB)
TSB
09-8-1 4.0L COOLANT LEAK - RADIATOR - BUILT ON OR BEFORE 8/8/2006
Publication Date: April 9, 2009
FORD: 2006 Explorer
2007 Explorer Sport Trac
MERCURY: 2006 Mountaineer
ISSUE:
Some 2006 Explorer, Mountaineer and 2007 Explorer Sport Trac vehicles built on or before 8/8/2006 and equipped with a 4.0L engine may experience coolant leaking from the radiator.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace the radiator with the updated radiator following Workshop Manual (WSM), Section 303-03.
NOTE: NOTE: A REVISED FAN STRATEGY IS ALSO AVAILABLE FOR THESE APPLICATIONS
Reprogram the Powertrain Control Module (PCM) to the latest calibration using IDS release 58.2 and higher. This new calibration is not included in the VCM 2008.11 Calibration files may also be obtained at
www.motorcraft.com.
PART NUMBER PART NAME
6L2Z-8005-AD Radiator
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
090801A 2007 Explorer Sport Trac 4.0L: Replace The Radiator; Reprogram The PCM (Do Not Use With 12650D, 8005A, 8600A, 8616A) 1.8 Hrs.
090801A 2006 Explorer, Mountaineer 4.0L: Replace The Radiator; Reprogram The PCM (Do Not Use With 12650D, 8005A, 8600A, 8616A) 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
8005 01
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2009 Ford Motor Company
