eeprete
- May 20, 2010
- NY
- 2003 Explorer Limited 4.6
Hey there, I am new here, and hoping someone can help or has experienced something similar.
Been having a few issues with my 2003 Explorer Limited of which both myself and my father (35 yrs as a top level mechanic) are dumb-founded by.
1. Started having coolant loss back in the fall. It would be slow loss where it would be a month or so and then I needed to add coolant/water (about 1 jug).
2. Vehicle has overheated twice now, once about 3 months ago, and once last night. Gauge always spikes, never slowly goes up, so no hint it's on the verge of occurring. I was within 5 minutes from home on both occasions so went immediately home.
3. Never any evidence of any leaks, no puddles no wetness anywhere etc. We've checked radiator, hoses, water pump, intake, everywhere.
4. Doing a system pressure test, showed slow dropoff of pressure (about 2 lbs over 20 minutes), so it's going somewhere.
5. Doing a system vacuum test showed the system held vacuum fine, and there was never loss of vacuum.
6. My father also has also checked for gases in the coolant. That too was negative, so it's less likely this is a head gasket failure.
7. I recently had some engine miss codes showing up in the last month. Changed plugs and boots and that seems to have remedied that problem, however one of the plugs was rusty.
I am on the verge of tearing apart the whole top end. I suspect maybe the intake is leaking on the underside and the heat of the engine is evaporating it hiding any clues? Is that too far fetched?
Any help, advice, tips on where to look is appreciated. Thanks.
