Hi! Thanks for getting back. How is your explorer going at the moment? Do you still experiencing the same problem with coolant loss?
I bought my explorer from a friend and started studying what I need to check first before removing the heads. She had also issues with coolant loss and took it to a garage for checks which they could not find anything. I'm unsure and doubt she has gone for all the pressure, leak down and vacuum tests. The signs I picked up so far is thick sludgy milky build up down the oil filling hole.
I found it interesting that your cylinder 2 seems to show signs of issues. Have you checked the results after the rebuild?
My thinking is to do a pressure leak test in each cylinder chamber followed by a compression test as you did. The sign for head gasket seems there due to the thick milk sludge in the oil fling line. Would you say that could be from something else? Apart from your oil cap that had sludge underneath it, did you have it down the oil filling line too at first?
Also, before you done your head rebuild, did your engine light stay on all the time?
Sponzbob!
