rochestercam
- March 15, 2008
- Rochester NY
- '92 Sport 4x4
Girl I was following behind was driving, truck was shifting smooth and all, she stopped at a stop sign, and could not get it to shift into gear, clutch pedal was to the floor as should be. I tried, and it just was like the shifter felt like it was against a steel wall, just wouldnt budge out of nuetral. I had her keep it in neutral and I pushed her 20 feet or so with my truck and she was able to shift into first and through all gears. I had to do this pushing to start her out at quite a few lights and stop signs. When we went to finally leave where we got to, it wouldnt shift into reverse, she would try to but it would just do the grinding sound/feel with the shifter. I was able to finally get it to go into gear, second, and then all gears would work. I shut if off with it in neutral, had her jump in and told her it would go in reverse, she put it in reverse with the engine on, traveled 20 feet or so came to a stop, tried to go again and truck wouldnt move. With the clutch in and out, the shifter will move like when you are shifting gears, but the truck just stays at a stand still and will not move. I should also note that she just purchased this truck, she drove it home for about a 60-70 mile trip and it drove fine, previous owner had a new clutch installed and the fluid reservoir is full. The clutch is not hard to press to the floor.
Anyone who can diagnose or help get her back on the road would greatly be appreciated. Thanks!
roccam.
roccam.
