bdavid
- January 9, 2014
- Arizona
- 2007 Ford Explorer
Hello everyone,
I need some advice.
I have an 07 Explorer with a 4.6l with the 6R60 tranny with 66k.
I needed to change out the radiator due to a crack in the plastic end tank.
The radiator was replaced and I refilled the tranny to the correct level using Amsoil SP (around 2 quarts).
When I took it out for a 20 minute test drive, she drove and shifted fine.
As I backed in to the driveway, I felt the tranny make a small clunk. When I put her back into drive, she hesitated but went in. Took her for a drive around the block and she wouldn't shift out of first gear. I tried to shift into reverse but all she did was rev and slowly move backwards. I pulled back into driveway and checked the fluid level and it was fine. I came inside and started mumbling a few choice 4 letter words and started searching the internet for a solution and found this excellent forum.
The next morning, I borrowed a friend's scan tool and pulled a P0731 error code (Gear 1 Incorrect Ratio). I started her up and she went into reverse without any problems. I took her out for a 10 minute drive and she shifted great through all 6 gears. Came back home and put her in reverse and I felt the same slight clunk and she wouldn't back up. Put her back into drive and she was again stick in 1st gear.
After then spending several hours searching the internet, to me it sounds like one to the solenoids are sticking since what I've read that the 1st and reverse gears share the same circuit. The question I have is, should I change out the valve body or can I just buy the solenoids and keep the stock valve body? Or maybe the better question is my assumption correct about the solenoids? I'm going to change out the fluid and filter asap and I'll pull the valve body to take a look but I'll looking for more advice from much more knowledgeable than me?
Sorry for the long post but I need some help.
Thanks,
Brian
I need some advice.
Thanks,
Brian
