Boro Buzzie
- November 27, 2009
- Murfreesboro, TN
- 1993 Ranger XLT
Good evening,
I've got a 93 Ranger that won't start. It's a 5 speed regular cab with just the 4 cylinder in it, about 220K miles. I've managed to put the trans back together in two attempts with new clutch parts, and master and slave cylinders. (After the first attempt it did start with a new battery and ran easily for 45 - 60 minutes, but wouldn't shift into gear. So I took it all apart again and put in a new slave cylinder.)
It took me about 14 months to get it ready the second time, and I'd charge the battery every month or two. When I went to start it and test the trans, the battery had lost enough juice that it wouldn't turn over. At that point I should have tried jumping it off one of our cars. But instead I tried hitting the 100 amp engine start on the Craftsman charger I have. I'm wondering now if I might have fried any wires or circuits, and it didn't start anyway.
A week later I had a new battery, put it in the truck, and it will crank great now. But still no starting - not even coughing like it's interested. I did pour a half cup of gas down into the air intake duct, and with that it did run for 10 seconds to burn up just that gas. So I'm glad the spark plugs still want to work.
I've checked the fuel pump fuse, fuel pump relay, and inertia safety switch for continuity, and they're ok. Today I put in a new fuel filter and I'll try it again tomorrow. By turning the key I don't get that warm and fuzzy hum of a Ford fuel pump (we've had a Tempo and an F150), so I'm thinking fuel pump. But could it also be the PCM, if I managed to fry it during the attempt with the dead battery? One other thing that strikes me strange is that the wire leading to the inertia switch reads about 6-1/2 volts to ground, not zero or 12. This evening I was reading in my Chilton's how to remove the gas tank, so that might be the next step. There's not a ton of room between the top of the tank and the bed, and I'd like to check the power going to the fuel pump.
Thanks for listening, and I'd appreciate any suggestions you might have;
Boro Buzzie
Boro Buzzie
