Fordman6996
- August 3, 2001
- South Dakota
- '08 Limited 4.0L SOHC V6
Hello,
I have a big problem with my 94 X and i'm going nuts on whats wrong with it. first one thing i just had my transmission rebuilt about a year ago and it seems the the seal around the shifting linkage is leaking I called a tranny shop and had it checked out they said that where that seal is leaking is a weak part of the transmission and since this is my second rebuilt tranny the previous shop that got my casing probably didn't get me a brand new one and that its worn in that spot making it leak he wants to charge me 400.00 for a new case then to pull out the guts of my tranny look it over and install it in the new one with fluid is a 1000 bucks I don't have that kind of money and I think he just wants to sell me a new case is there any fix for that? Also I have a rattling/knocking sound either from the tranny or the engine, it sounds more like the engine. It starts doing it after it been warmed up really good at idle or when I'm going to down the interstate about 75 to 80 when ever I flutter the gas you know that time where you can acelerate with out kicking up the rpms to 3000. Its really noticable from inside the car going down the road. would it be a pushrod loose or lifter or rocker arm? or could it be the tranny. the transmission it self shifts fine so I don't think its that. I also though on the 4.0 that hey had self adjusting ones the vehicle has 130.000 miles on it I would appreciate it if some one could help me I'm almost to the point of getting a new motor.
