crazyflights
- August 31, 2008
- St. Joseph, MO
- 97 1 ton Jeep
I am working on my 97 explorer, all stock engine tranny, has been running/shifting fine, all the sudden now runs in park can rev it up fine, drives in reverse can rev up fine,, can be reved up in neutral, but now when put it in drive it will idle forward fine, but give it any gas, u can watch the check engine light flicker and rpms drop like your shutting off the engine, let off will idle, stay in throttle and it will die. The other day pulled few codes
P0755 Shift Solenoid B error
P0705 Trans Ranger sensor error
P1746 EPC Solenoid Open Circuit
P0500 VSS error-which has done for awhile
Today change EPC, TCC and shift solenoid sensor, but havent had chance to run codes, but still doing same thing, I have checked my Enertia Switch and it is fine?
Anyone ever had problem like this.
Please help would like to take this rig to Smorr, Halloween get together.
