Anabolic3xploder
- March 12, 2013
- connecticut
- 1998 explorer sport 4x4
what are the best plugs to install in my 98 explorer v-6 SOHC ?
Single platinum where never recommended for Explorer's ignition system.i run Autolite Platinum in mine never had any problems with them.
Well, then they are not "the best" for the job.
It's not only "lasting" issue for plugs, they will increase also the arc voltage on that bank - reflected on coils life/temperature, reflected on wires aging faster...
So, the consensus is autolite platinum or double platinum are best. Problem solved.
Yeah, I responded to a "best spark plug" thread and I knew better.
Slap me if I do it again.
BINGO! Thousands of OEM Motorcraft SP500 plugs installed on 4.0L SOHC's without a single complaint.Well I've got a nice V6 over here and I believe it has Motorcraft SP500 in it.
