It is possible to have two things fail.
In the car I bought, the drivers window motor was bad, there was a broken ground wire in the drivers door hinge area, the dome lights stayed on, the volume control on the radio only increased loudness, the thermostat housing leaked, the ball joints were without rubber booties, the tires were bald, the moon roof wouldn't open (and it leaked), The outdoor air flap in the air conditioner had fallen down, the flapper that chooses dashboard vents or floor vents didn't work, the rear A/C wouldn't change temperatures, one puddle light was burnt out, the turn signals didn't flash, the gas gauge frequently got stuck on, "empty", the car smelled of dog so bad it would drive you out on a hot day, the windshield wiper cowling allowed rain to puddle on top of the engine, the battery failed in a week, the window lock button and both sun visors were missing, the transmission drain plug leaked, it only had one ignition key, and nobody knew the keypad entry code.
Consider yourself lucky if your car only has two problems.
