DMF0104
- February 23, 2013
- delaware
- 95 explorer limited
Since you mentioned your only key is cracked you might try to clone it. Cloning a key is less expensive than programming the PCM to recognize a new key. I've seen machines with the capability in Ace Hardware and even Walmart. In order to clone a key the machine must read the microchip code on the old key. If the machine can't read it then you know the key is the problem.
That's an excellent idea , and only fifty dollars as opposed to whatever they'll charge at ford dealer! Now THAT is definitely worth a try. Need a second key anyway. Down side will be if machine can't read it, cause I'll have to get the car rekeyed(according to all ford's literature on the subject)Thanks!
