Postalsnap
- March 22, 2003
- Houston, Texas
- '98 Eddie Bauer
I've got a '98 Explorer Eddie Bauer with the automatic climate control. In the winter it worked great. I set it at 73 degrees and cruised. Now that it's hot here in Houston, Texas (90 outside temp), the automatic setting isn't so automatic. If I set the temp over 68 degrees, the fan kicks on full blast with nothing but 120 degree heat. The A/C doesn't kick on until I take it to 67. During the cold months, it would mix outside air with heat to make it set temperatures.
At first I thought it may be low on freon, so I gave it a shot of 134a which makes it blow REAL cold. But I still have problems with temp regulation.
Is there a temperature probe/sensor on the inside of the cabin that may have malfunctioned? What could cause the absolute total heat or A/C. There's no inbetween anymore.
